welded rods
Goto page 1, 2  Next
JDguy1
PostPosted: Wed Mar 27, 2013 5:31 pm    Post subject: welded rods Reply to specific post Reply with quote
What are you guys thoughts opinions on welded rods? Do you just butt the two ends weld it and call it good? or do you box them in? Any pics?
VicS
PostPosted: Wed Mar 27, 2013 6:00 pm    Post subject: Re: welded rods Reply to specific post Reply with quote
I have some in our Allis Mazda big end and big block Ford small end. Just butted together. Kieth Merfield welded them. I had them straightened, balanced and cryogenic (put them in a freezer with liquid Nitrogen in a oven and heated them to 350 I think)Did the entire engine with it apart. That was 10 yrs ago. No problems, but I do think about it, and go real easy on the motor. Vic
Earl-IL
PostPosted: Wed Mar 27, 2013 6:08 pm    Post subject: Re: welded rods Reply to specific post Reply with quote
I saw a butt weld rod break on a F30 at idle and it wiped out the block manifold & carb.Many times & stood beside that tractor to adjust the carb. I thank God I wasn't there that day. Boxed rod only!!!!!!
Ray Tellin
PostPosted: Wed Mar 27, 2013 8:04 pm    Post subject: Re: welded rods Reply to specific post Reply with quote
Do you remember how much you had in them compared to a billet set?
Josh Blackburn
PostPosted: Thu Mar 28, 2013 3:41 am    Post subject: Re: welded rods Reply to specific post Reply with quote
Depends on your engine. We have put some good size g's together welded boxed rods. One 840 cube with 12 to 1 compression. All of our personal big deeres are welded rods. I built a good size B for a gentlemen in NY and it has welded rods not boxed from top to bottom, he turns it at around 22-2300 rpm or better. There's some vids on YouTube. http://m.youtube.com/#/watch?v=78qAAhvcFFs&feature=plcp. That being said I have had succes with welded Rods. If done correctly they will hold. I've seen non boxed Rods in a 883 cube g. So far they have held but I wouldn't want to be on the seat. What engine are you trying to build? SiZe and rpm are a factor.
Josh Blackburn
PostPosted: Thu Mar 28, 2013 4:07 am    Post subject: Re: welded rods Reply to specific post Reply with quote
http://m.youtube.com/watch?v=Uok7XZ4zJdw&feature=relmfu
jdth
PostPosted: Thu Mar 28, 2013 5:23 am    Post subject: Re: welded rods Reply to specific post Reply with quote
I"ve had welded rods in tractors for over 10 years. The success of the welded rod depends on who & the process the rods are welded. I also have seen welded rods break, ironically, the rod broke slightly (about an inch) up form the welded area. The tractor was just idling at the time. Billet rods are a great direction to go, but not necessary in all builds. Just my opinion.
Pete Petznick
PostPosted: Thu Mar 28, 2013 5:53 am    Post subject: Re: welded rods Reply to specific post Reply with quote
CAP Bros Motorsports has a variation that is stronger than butt welding and lighter than boxing.
Email or call
Pete Petznick
Capbrosms@gmail.com
816.308.8878
Mopar-Harris
PostPosted: Thu Mar 28, 2013 5:56 am    Post subject: Re: welded rods Reply to specific post Reply with quote
Oopppsss did not rrealize I was not signed in.
Email or call
Pete Petznick
Capbrosms@gmail.com
816.308.8878
baldwin racing
PostPosted: Thu Mar 28, 2013 7:46 am    Post subject: Re: welded rods Reply to specific post Reply with quote
my rods would cost me $375 to get done if i supply them and they just get welded.....vs billet ones $1,200
JDguy1
PostPosted: Thu Mar 28, 2013 8:30 am    Post subject: Re: welded rods Reply to specific post Reply with quote
Its a smaller G using 4020 and G rod, would you box around the weld or box the whole rod?
VicS
PostPosted: Thu Mar 28, 2013 10:06 am    Post subject: Re: welded rods Reply to specific post Reply with quote
At the time Billet were $1000 Keith Made the rods and stroked the crank to 5.75 for that. It cost $300 to freeze it. Friend at the speed shop balanced and checked for straight and length for free. Keith had already done that they were fine.
Gary Baker
PostPosted: Thu Mar 28, 2013 2:30 pm    Post subject: Re: welded rods Reply to specific post Reply with quote
Why would you even think of using welded rods. Good chance of breaking and injuring you or somewone else. Billet rods are cheaper in the long run.
DAVE Thompson jr
PostPosted: Thu Mar 28, 2013 4:42 pm    Post subject: Re: welded rods Reply to specific post Reply with quote
I agree with what Gary Baker said. Buy a good set of billet rods and do it correct. With the stroke people are putting in engines and the rpms I would only use the best. I find it hard to believe that Josh Blackburn is using welded rods in his engines. I know the guy who taught him to make stroker cranks wouldnt have used welded rods.
Travis M
PostPosted: Thu Mar 28, 2013 9:04 pm    Post subject: Re: welded rods Reply to specific post Reply with quote
I sold a tractor to gary with welded rods in it which he can tell you what happened to it. No more welded rods for us
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
