Massey Harris 22 positive ground 6v won't charge
Brent Combs
PostPosted: Thu Mar 28, 2013 6:02 pm    Post subject: Massey Harris 22 positive ground 6v won't charge Reply to specific post Reply with quote
I am in the process of restoring a MH-22 and It is all original including the 6v generator. The tractor is positive ground. Ive had the generator tested and it is charging well. Is there something simple that I am missing? Tractor does not have a voltage regulator and the charge wire from the generator goes to the terminal on the start switch that supplies power from the battery.
AllanC
PostPosted: Thu Mar 28, 2013 7:03 pm    Post subject: Re: Massey Harris 22 positive ground 6v won't charge Reply to specific post Reply with quote
There must be at least a cutout if not a regulator. The cutout is required to disconnect the generator from the battery when it is not running. Find the cutout and jump it momentarily to polarize the generator and see what happens. That will "polarize" the generator so it can start charging.
Tom from Buckeye Lake
PostPosted: Fri Mar 29, 2013 5:25 am    Post subject: Re: Massey Harris 22 positive ground 6v won't charge Reply to specific post Reply with quote
I had a Farmall BN without a Reg. It did have a cutout, the Gen. had a third brush that was moveable to set charge rate. Could yours be the same and the brush needs adjusted ?
Jason1Pa
PostPosted: Fri Mar 29, 2013 6:59 am    Post subject: Re: Massey Harris 22 positive ground 6v won't charge Reply to specific post Reply with quote
Also remember that a gen sometimes doesn"t start charging until it hits a certain RPM.. Did you ever have the engine full throttle yet? When on a test bench (without engine noises) you can slowly increase the RPMs and the gen will start to make a different sound at a certain speed then you will know when it kicks in. The charging will continue at a lower speed but it must kick in first
