Seal removal procedure technique
stronics
PostPosted: Fri Mar 29, 2013 2:46 pm    Post subject: Seal removal procedure technique Reply to specific post Reply with quote
What is your favorite way to remove a seal? On one that has no bottom stop?
Any information would be helpful, thanks
David
El Toro
PostPosted: Fri Mar 29, 2013 4:18 pm    Post subject: Re: Seal removal procedure technique Reply to specific post Reply with quote
I had to replace the seals on our Troy Bilt tiller. On the one side I drilled a small hole and threaded a screw into the hole that was attached to a sliding bar puller. First I had to drain all the oil. The other side had small cap screws and I removed the cover. Then I used a brass drift to remove the old seal and tapped in the new seal. This is behind the tine holders
and you need to remove them and a long 1/2" cap screw to gain access to the seals. Hal
DiyDave
PostPosted: Sat Mar 30, 2013 2:26 am    Post subject: Re: Seal removal procedure technique Reply to specific post Reply with quote
If you can pull the shaft out, it's real easy to pull one out with a with a seal puller, that is shaped like the letter T, with the upper bar of the R made up of 2 curves, pointing down at the outer ends.
seal puller
