Massey 85
Brendon Warren
PostPosted: Fri Mar 29, 2013 3:02 pm    Post subject: Massey 85 Reply to specific post Reply with quote
Is there any good way to flush the hydralic system out on an 85. Mines more water than oil, was curious if anyone came up with a way to get it out?
willowbk
PostPosted: Fri Mar 29, 2013 5:42 pm    Post subject: Re: Massey 85 Reply to specific post Reply with quote
just did mine w/ same type issues,drained all 3 plugs,removed power steering pump(cleaned screen),removed strainer and replaced(next to hydro pump),sprayed alittle diesel thru inspection covers and power steering pump cavity.
i dumped in about 5 gallons of napa hydro/trani fluid and ran tractor for a bit then drained again. i also removed small drain plug on front of tractor on power steering brain(behind grill screens/center bar)that had the most water. i finally replaced w/ 10 gallons plus of new fluid. you could probably get some cheaper hy/tran for 1st flush then use better for final.
good luck.
View user's profile AIM Address
