Cub Cadet 125
jb9959
PostPosted: Sat Mar 30, 2013 6:22 pm    Post subject: Cub Cadet 125 Reply to specific post Reply with quote
My tractor was running fine and only used a small amount of oil. I had to add half-quart after mowing my 2 acres.
All of a sudden it started smoking and I have to add a quart for every tank of gas. (Approx 45 minutes.)
Any suggestions would be appreciated.
Husker44A
PostPosted: Sat Mar 30, 2013 7:17 pm    Post subject: Re: Cub Cadet 125 Reply to specific post Reply with quote
You broke a piston ring!!!! Might check the crankcase vent too.
Traper
PostPosted: Sun Mar 31, 2013 9:31 am    Post subject: Re: Cub Cadet 125 Reply to specific post Reply with quote
jb9959
Check for clog under shielding causing engine to run hot.traper
Bill Lisbon
PostPosted: Sun Mar 31, 2013 11:17 am    Post subject: Re: Cub Cadet 125 Reply to specific post Reply with quote
I would say it is time for an engine overhaul. The Kohlers are one tough engine, and can be rebuilt many times. I know of some that have over 6000 hours on them.
jb9959
PostPosted: Sun Mar 31, 2013 6:34 pm    Post subject: Re: Cub Cadet 125 Reply to specific post Reply with quote
Thanks, I'll check these suggestions tomorrow.
JB9959
dhermesc
PostPosted: Mon Apr 01, 2013 6:31 am    Post subject: Re: Cub Cadet 125 Reply to specific post Reply with quote
That would be my guess. If the vent is clear I'd quit using it until you get the engine repaired. Broken rings can really mess up the cylinder walls. The K301 is really easy to overhaul, the hardest part I've run into with them is getting the PTO clutch off.
