What model plow is this?
WGreufe
PostPosted: Sun Mar 31, 2013 7:50 am    Post subject: What model plow is this? Reply to specific post Reply with quote
I found a plow for sale on the local Craigslist but I am not sure of model and the seller didn't know either.
Looking at the picture I am not seeing how this would clear the tire on my 2020.
WGreufe
PostPosted: Sun Mar 31, 2013 8:15 am    Post subject: Re: What model plow is this? Reply to specific post Reply with quote
Another pic
Tx Jim
PostPosted: Sun Mar 31, 2013 8:31 am    Post subject: Re: What model plow is this? Reply to specific post Reply with quote
I think it's a F125 because it appears to have spring trip standards. The rotary cutter in the photo is a X09 series which is one of JD better cutters.
donjr
PostPosted: Sun Mar 31, 2013 9:12 am    Post subject: Re: What model plow is this? Reply to specific post Reply with quote
Looks like an earlier one with those shares...
WGreufe
PostPosted: Sun Mar 31, 2013 9:22 am    Post subject: Re: What model plow is this? Reply to specific post Reply with quote
donjr wrote:
(quoted from post at 13:12:43 03/31/13) Looks like an earlier one with those shares...
It is missing the landing lever from what I can see in the pic.
long green line man
PostPosted: Sun Mar 31, 2013 9:37 am    Post subject: Re: What model plow is this? Reply to specific post Reply with quote
Because of long brace rod going back to third bottom & front bottom on right side of right draft link pin ; It has to have been cut down from a 4 bottom ... PC- 806 ....Has older GP(general purpose) bottoms....
WGreufe
PostPosted: Sun Mar 31, 2013 10:32 am    Post subject: Re: What model plow is this? Reply to specific post Reply with quote
long green line man wrote:
(quoted from post at 13:37:52 03/31/13) Because of long brace rod going back to third bottom & front bottom on right side of right draft link pin ; It has to have been cut down from a 4 bottom ... PC- 806 ....Has older GP(general purpose) bottoms....
That's the part that was throwing me off too. The front coulter being ahead of the three point frame.
long green line man
PostPosted: Sun Mar 31, 2013 10:56 am    Post subject: Re: What model plow is this? Reply to specific post Reply with quote
By looking close at pic. I really think it a earlier model F120 PC-711; It do'nt have the extra fore-aft.clearance (frame streched back as much) as the F125...
long green line man
PostPosted: Sun Mar 31, 2013 11:06 am    Post subject: Re: What model plow is this? Reply to specific post Reply with quote
It's got 2 piece moleboards , blacksmith sharpenable GP. shares; most plows that age have HS. (highspeed) moleboards...
wilamayb
PostPosted: Sun Mar 31, 2013 1:27 pm    Post subject: Re: What model plow is this? Reply to specific post Reply with quote
Because of the long coulter beam in the front I'm almost totally sure that it is an F125 4 bottom made into a 3 bottom by cutting the box tube and putting the tail wheel on the 3rd bottom.
The front coulter leading so far forward on the 4/5 bottom plows keeps them from being used on 2 cylinder tractors.
The easy way to spot a 3 bottom F125 is by its smaller square beam. It has the same size beam as used on the F115/F120 plows. The F125 4 and 5 bottom plows used the larger beam as seen on this plow.
Also note that the line of draft is different for a 4 bottom F125 than it is for a 3 bottom. It will not draft correctly. The 1250 works fine by just cutting it off from 5 bottoms all the way down to 3 but the F125 is a different story. The cut off 125's will wear the landsides and continually pull the frontend into the plowed ground. I know because I've owned two of the cutoff F125 plows. They just dont work correctly.
WGreufe
PostPosted: Sun Mar 31, 2013 4:55 pm    Post subject: Re: What model plow is this? Reply to specific post Reply with quote
I think I will pass on this one and find something better.
George S. in the real NY
PostPosted: Tue Apr 02, 2013 4:05 am    Post subject: Re: What model plow is this? Reply to specific post Reply with quote
The plow is a F120 series. 120 because it has trip bottoms and the lower hitch cross bar is below the frame. F115 and 125 have bar thru the frame. Looking at the location of the top link attachment, this plow was originally a 4 btm. As it is now the center of the pull or draft is off set to the left of the plow. Also, parts book shows the 4 btm with the right coulter support like on this plow. 3 btm is different. I would guess that plow would have been a fight to keep going in any sort of straight line.
