3204 check valves
Stick welding
PostPosted: Sun Mar 31, 2013 3:23 pm    Post subject: 3204 check valves Reply to specific post Reply with quote
Further to my previous post, I have figured the check valves in the transfer are bad or the whole transfer pump is bad. After cleaning the screen it ran longer but then started acting up again. How do you change the check valves in the transfer pump? Do you remove the whole transfer pump? If the transfer pump has to come off, is there anything behind it to be aware of and how do you get the bottom bolt out? It looks like it's kind of hard to get to.
Bob/Ont
PostPosted: Sun Mar 31, 2013 4:58 pm    Post subject: Re: 3204 check valves Reply to specific post Reply with quote
Take it off and apart. Pin on back rides on pump cam. Take note of direction check valves are installed .
Later Bob
Stick welding
PostPosted: Sun Mar 31, 2013 7:07 pm    Post subject: Re: 3204 check valves Reply to specific post Reply with quote
Thanks Bob. On the other post I mentioned there was some fibrous stuff I pulled out of the screen. I was wondering if there's some kind of other screen in the hex piece in addition to the metal screen? At first I thought it was brass filings but it was more like really strong fine strands of string. Would it be a good idea to get a new screen assembly?
Bob/Ont
PostPosted: Mon Apr 01, 2013 5:02 pm    Post subject: Re: 3204 check valves Reply to specific post Reply with quote
If you can clean it and it isn't coming apart it should be fine, if not replace it. That stuff might be in the check valves too. It is very common for the check valve flaps to break up. You are getting fuel just not enough for any power.
Later Bob
Stick welding
PostPosted: Mon Apr 01, 2013 5:08 pm    Post subject: Re: 3204 check valves Reply to specific post Reply with quote
I got the new check valves and all the o-rings to reassemble. It cost $15.99 at Union tractor. Trying to find the screen assy. took forever cause it wasn't listed with the transfer pump and every other picture of a transfer pump showed a hand primer that I don't have. Finally found a good picture and I should have the right parts.
dpendzic
PostPosted: Tue Apr 02, 2013 10:46 am    Post subject: Re: 3204 check valves Reply to specific post Reply with quote
this is what I have
