Locating Pin on seat retaining stud
Big_T
PostPosted: Tue Apr 02, 2013 5:01 am    Post subject: Locating Pin on seat retaining stud Reply to specific post Reply with quote
I have a Ford 3600 and am trying to start into a little restoration. On removing the seat assembly, the rear retaining stud came out completely as the nut was seized. It then became obvious that the stud was also some kind of locating pin (internally). My problem now is that the pin won't go back into place as the lower hole (inside the Lift Cover) has moved forward. I can see down into the hole of the Lift Cover and only the back 1/3 of the lower hole is visible.
If I force the Yoke of the Draft Control Main Spring Assembly forward a little the bottom hole does move, but not enough to allow the pin/stud to screw down in.
I have the I&T Shop Manual but it doesn't refer to this pin in any way.
The tractor is a European model (made in Antwerp ???).
Does anybody have an idea how to correct this.
souNdguy
PostPosted: Tue Apr 02, 2013 5:12 am    Post subject: Re: Locating Pin on seat retaining stud Reply to specific post Reply with quote
you can pop the top cover and get it back in.. as you notices it's a draft part.
you'd be surprised at how many I've seen missing.. Smile
sotxbill
PostPosted: Tue Apr 02, 2013 7:09 am    Post subject: Re: Locating Pin on seat retaining stud Reply to specific post Reply with quote
Big_T wrote:
(quoted from post at 08:01:19 04/02/13) I have a Ford 3600 and am trying to start into a little restoration. On removing the seat assembly, the rear retaining stud came out completely as the nut was seized. It then became obvious that the stud was also some kind of locating pin (internally). My problem now is that the pin won't go back into place as the lower hole (inside the Lift Cover) has moved forward. I can see down into the hole of the Lift Cover and only the back 1/3 of the lower hole is visible.
try pulling back out on the yoke till it lines up. you may have to break the yoke loose and unscrew it a bit to take the pressure off and then put it back.
Oh, and make sure its not in draft control IIRC.
Big_T
PostPosted: Thu Apr 04, 2013 12:58 pm    Post subject: Re: Locating Pin on seat retaining stud Reply to specific post Reply with quote
THANKS, sotxbill and Soundguy. I really appreciated your help. A friend helped me apply a little bit more force on the rocker and she lined up fine. It wasn"t an alignment hole, it was an alignment slot. Thanks again. You guys are lifesavers.
