briggs vangaurd no charge
fast puller
PostPosted: Wed Apr 03, 2013 5:04 pm    Post subject: briggs vangaurd no charge Reply to specific post Reply with quote
14 hp vanguard replaced regulater still no charge
G1355
PostPosted: Wed Apr 03, 2013 5:32 pm    Post subject: Re: briggs vangaurd no charge Reply to specific post Reply with quote
Good connections? Got the right wires hooked up to the regulator correctly.
fast puller
PostPosted: Wed Apr 03, 2013 6:50 pm    Post subject: Re: briggs vangaurd no charge Reply to specific post Reply with quote
yes just like the one i changed out
G1355
PostPosted: Wed Apr 03, 2013 6:52 pm    Post subject: Re: briggs vangaurd no charge Reply to specific post Reply with quote
My brother bought a new one a few years ago, had same problem took it back, got another new one, worked fine maybe you got a bad one. Someone else will have more suggestions.
joe csuti
PostPosted: Thu Apr 04, 2013 2:10 am    Post subject: Re: briggs vangaurd no charge Reply to specific post Reply with quote
Check for an inline fuse in on eng wiring,briggs may have installed fuse in alt output lead,after that check owners manual for a wiring diagram,equipment mfg may have installed a fuse in wiring harness for alt output,also check for loose/bad plug in connectors in wiring harness & loose/bad connector/connections at ign sw.
If no blown fuse found & all connectors/connections good,tight & clean,disconnect output DC output lead on regulator,run eng 3/4-full throttle,measure output voltage,should be 13-14.5v DC,if no output from reg,disconnect stator leads from reg & measure AC voltage output from stator,this voltage may be between 20 & 40v AC depending on amp output of stator as briggs used four different amp output rateing stators for regulated output charging systems on vanguard eng,you may need a service manual for eng to test/troubleshoot & id alt stator,the AC output voltage on each stator is different depending on amp output of same.Possible causes of no AC output from stator,stator bad or missing/broken magnets in flywheel.
El Toro
PostPosted: Thu Apr 04, 2013 3:11 am    Post subject: Re: briggs vangaurd no charge Reply to specific post Reply with quote
It's probably your stator. Do as Joe suggested
and measure the AC voltage. Hal
