329 combine engine - low oil pressure
raycefan
PostPosted: Fri Apr 05, 2013 6:25 am    Post subject: 329 combine engine - low oil pressure Reply to specific post Reply with quote
This message is a reply to an archived post by cooney minnie on August 12, 2012 at 10:42:11.
The original subject was "329 combine engine low oil pressure".
low oil pressure jd 5410 tractor, bearings ok, oil pum p and tubes ok, replaced pressure spring, still no answers,maybe oil cooler leaking, going there next. any ideas, thanks
tim s
PostPosted: Fri Apr 05, 2013 6:37 am    Post subject: Re: 329 combine engine - low oil pressure Reply to specific post Reply with quote
I have seen a few of these models have the drive gear slip on the oil pump shaft, they are a taper with "no" key, when I repaired them I went with a new shaft/gear, scuffed it up a bit and loc-tited them...
Tx Jim
PostPosted: Fri Apr 05, 2013 8:03 am    Post subject: Re: 329 combine engine - low oil pressure Reply to specific post Reply with quote
Low oil pressure on a 4 cyl engine could be attributed to faulty balancer shaft brgs.
