case 2290
manitoba farmer 12
PostPosted: Sat Apr 06, 2013 4:22 pm    Post subject: case 2290 Reply to specific post Reply with quote
i have a case 2290 stopped moving it still has hydraulics doesn't move in any gear with the clutch out there a lot of pressure to shift it in gear with the tractor running
Agri King
PostPosted: Sat Apr 06, 2013 6:31 pm    Post subject: Re: case 2290 Reply to specific post Reply with quote
Is it a powershift?
manitoba farmer 12
PostPosted: Sat Apr 06, 2013 6:50 pm    Post subject: Re: case 2290 Reply to specific post Reply with quote
its not the power shift it was moving then stopped
Agri King
PostPosted: Sat Apr 06, 2013 7:00 pm    Post subject: Re: case 2290 Reply to specific post Reply with quote
So ...........it is a powershift tractor?
manitoba farmer 12
PostPosted: Sat Apr 06, 2013 8:16 pm    Post subject: Re: case 2290 Reply to specific post Reply with quote
yes
manitoba farmer 12
PostPosted: Sat Apr 06, 2013 8:17 pm    Post subject: Re: case 2290 Reply to specific post Reply with quote
yes its a power shift tractor
Thad
PostPosted: Sun Apr 07, 2013 3:32 am    Post subject: Re: case 2290 Reply to specific post Reply with quote
Most likely a torquelimiter failure. Try to shift it into gear on the 4 speed side with the clutch up. If it will go into gear with no grinding or scraping of the gears you are not turning the trans. thad
manitoba farmer 12
PostPosted: Sun Apr 07, 2013 7:05 am    Post subject: Re: case 2290 Reply to specific post Reply with quote
the trans is turning in any gear it grinds when the clutch is up and the tractor is running
Case Nutty 1660
PostPosted: Sun Apr 07, 2013 7:26 am    Post subject: Re: case 2290 Reply to specific post Reply with quote
two thoughts here I have, one I have seen torque limitors still pull enough to make the trans turn with no load hence grear grind with clutch out
two I lost the rear brg on the main shaft in my 2290 and it allowed the shft to move away from the counter shaft and you could here the powershift change but no drive at all I do not remember if I had any gear grind, to check the mainshaft bearing you can remove the pto and see it behind the ring gear, the torque limiter is a split behind the engine, many times I have seen a torque limiter fail I have found trash from the drain plugs below the limiter these two may not be your problem but gives you a couple more ideas cnt
