educate me on WD hand clutches
jpapier
PostPosted: Sun Apr 07, 2013 10:25 am    Post subject: educate me on WD hand clutches Reply to specific post Reply with quote
Do the parts from three and two disk hand clutches interchange? My nephew has a WD45 older model with straight shifter and a very wore out 2 disk wet clutch.
Ted J
PostPosted: Sun Apr 07, 2013 10:53 am    Post subject: Re: educate me on WD hand clutches Reply to specific post Reply with quote
I doubt very much if that is a WD-45, as they all had the bent shifter. Sounds like you have a plain WD. Look on the right side of the motor, is there a plate there? Runs the whole length of the block. Its about 4" tall. As far as I know, the parts are not the same.
Brian G. NY
PostPosted: Sun Apr 07, 2013 3:17 pm    Post subject: Re: educate me on WD hand clutches Reply to specific post Reply with quote
All early WDs had the straight shifter handle. The curved shifter (with helical cut trans gears) began in 1952 with WD Serial #WD127007 and carried over to the WD-45s.
WD-45s beginning with Serial #WD165056 were also equipped with the 3 disc transmiision (hand) clutch.
Except for the third disc they are basically the same and most parts interchange.
As I have said before, "a manual is a wonderful thing".
jpapier
PostPosted: Mon Apr 08, 2013 11:35 am    Post subject: Re: educate me on WD hand clutches Reply to specific post Reply with quote
A curved shifter indicates production date not Wd or 45. LOL
Bill(Wis)
PostPosted: Tue Apr 09, 2013 5:58 am    Post subject: Re: educate me on WD hand clutches Reply to specific post Reply with quote
Have any of the shims been removed yet? (See item 3 below) You adjust the hand clutch by REMOVING shims.
