FE-35 loose transmission shift lever
Bart CA
PostPosted: Sun Apr 07, 2013 11:26 am    Post subject: FE-35 loose transmission shift lever Reply to specific post Reply with quote
The shift lever is loose and rotates on its base.
I looked in the parts list explosed view...
there is a pin at the base of the shifter that I suspect to be broken. There is not enough detail on the image.
Is it possible to replace the pin without removing the transmission cover ?
The tractor is at our summer place I would like to bring the proper tools and parts when I go there next time.
Thanks In advance.
Bart
samn40
PostPosted: Sun Apr 07, 2013 2:21 pm    Post subject: Re: FE-35 loose transmission shift lever Reply to specific post Reply with quote
This picture may help you. The new pin is splined at one end to lock in the housing. You will need a flat ended punch to drift the old pin out. Sometimes the new pin can be used to drive out the old pin, but if yours is broken it may take a bit of jiggling about to get the holes lined up. Check also that the cup is tight in the housing, this is held tight by a locknut/collar that has to be tightened with a 'C' wrench.
Sam
Bart CA
PostPosted: Mon Apr 08, 2013 6:14 am    Post subject: Re: FE-35 loose transmission shift lever Reply to specific post Reply with quote
Samn, Many thanks for your reply and for the explanation and the photo.
Greatly appreciated !!!
Bart
