massey steering problem
Robert J Hampton
PostPosted: Mon Apr 08, 2013 2:29 pm    Post subject: massey steering problem Reply to specific post Reply with quote
I have a 1977 245 massey ferguson. This winter I replaced bushings in the front axle, pin was fine, ball joints tight, and I still have play in the steering. I have looked for an adjustment on the steering box but did not find one. Any suggestions?
DavidP, South Wales
PostPosted: Tue Apr 09, 2013 1:20 am    Post subject: Re: massey steering problem Reply to specific post Reply with quote
Hello Robert,
From looking into this it seems that the 245 was fitted with the older mechanical type of steering and hydrostatic. If you have the older type then it is likely that the play will be in the rocker shaft tooth mesh items 52 and 17 in the diagram. There is no adjustment only replacement. You may also have wear in the top bearing of the steering column. Normally this can be adjusted after removing the steering wheel. In older tractors it is not uncommon to have to cut the steering wheel off.
Let us know which type you have.
DavidP, South Wales
Robert J Hampton
PostPosted: Tue Apr 09, 2013 2:17 am    Post subject: Re: massey steering problem Reply to specific post Reply with quote
I have power steering
