Oil pressure
Goto page 1, 2  Next
Aaron from Iowa
PostPosted: Mon Apr 08, 2013 5:31 pm    Post subject: Oil pressure Reply to specific post Reply with quote
Hello again, Smile
Well, the clutch noise went away, BUT.... It is reading 60-80 PSI oil pressure and is having a slight knock. I plan on draining the oil and replaceing the filter when I get a chance, but would like any opinions on the cause and what to look for if that doesn't clear it up. I don't remember the oil pressure being that high when it was parked. Kin of thinking maybe an oil line or something plugged? Been looking for my Ford manual, but it's been a few years since I set it down somewhere.
JCinKY
PostPosted: Mon Apr 08, 2013 5:37 pm    Post subject: Re: Oil pressure Reply to specific post Reply with quote
Aaron from Iowa wrote:
(quoted from post at 18:31:08 04/08/13) Hello again, Smile
Aaron, 60-80 lbs of pressure aren't even possible. I believe the pressure relief, behind the big 15/16" nut behind the radiator, is set around 35 lbs.
I would get a new gauge and see what you get.
As for the knock, try to isolate where it is coming from. An automotive stethescope or long screwdriver stuck to your ear will help. Is it a deep, throaty knock? A tapping? Increase/decrease with more/less throttle?
Post back
Royse
PostPosted: Mon Apr 08, 2013 5:54 pm    Post subject: Re: Oil pressure Reply to specific post Reply with quote
JCinKY wrote:
(quoted from post at 21:37:38 04/08/13)
Post back
Oh it's possible, I had an 8N that carried pressure like that with different
new gauges that I even tested in other tractors.
Pressure relief valve was stuck on mine.
I agree with isolating the noise, need to know where that's coming from.
JCinKY
PostPosted: Mon Apr 08, 2013 6:28 pm    Post subject: Re: Oil pressure Reply to specific post Reply with quote
Royse wrote:
(quoted from post at 18:54:33 04/08/13)
Post back
Exactly right Royse. If the can stick open the can stick closed...
Kirk West
PostPosted: Tue Apr 09, 2013 4:29 am    Post subject: Re: Oil pressure Reply to specific post Reply with quote
I"ve got a 2N that"s reading 50+ oil pressure. Already changed the oil and filter. Where is this pressure relief valve? Getting blue smoke so if pressure is too high, excessive blow by?
JCinKY
PostPosted: Tue Apr 09, 2013 4:37 am    Post subject: Re: Oil pressure Reply to specific post Reply with quote
Kirk West wrote:
(quoted from post at 05:29:43 04/09/13) I"ve got a 2N that"s reading 50+ oil pressure. Already changed the oil and filter. Where is this pressure relief valve? Getting blue smoke so if pressure is too high, excessive blow by?
The pressure relief spring and plunger is behind the big 15/16" nut on the very front of your 2N engine. It will be right beside the #3 plug nipple on your front mount distributor under the upper radiator hose. Just remove the nut and all three (nut, spring, plunger) will come right out; careful there is a little spring tension. The flat spot on the plunger is supposed to be there.
Blue smoke from the exhaust is rings/valve seals. Blow by would be smoke from the oil filler neck.
TheOldHokie
PostPosted: Tue Apr 09, 2013 5:34 am    Post subject: Re: Oil pressure Reply to specific post Reply with quote
Kirk West wrote:
(quoted from post at 08:29:43 04/09/13) I"ve got a 2N that"s reading 50+ oil pressure. Already changed the oil and filter. Where is this pressure relief valve? Getting blue smoke so if pressure is too high, excessive blow by?
No - higher oil pressure does not produce blow-by.
TOH
Kirk West
PostPosted: Tue Apr 09, 2013 5:44 am    Post subject: Re: Oil pressure Reply to specific post Reply with quote
Yes, I"ve got blue smoke out the oil breather too. I suspect I may have some stuck piston rings since this tractor sat more than ran. Also has ran cold for who know how long. Will check out the relief valve as soon as this blizzard blows by.
JMOR
PostPosted: Tue Apr 09, 2013 6:58 am    Post subject: Re: Oil pressure Reply to specific post Reply with quote
I would look to gauge first, then relief valve. Filter? Would you believe that the pressure will be the same, even if you put the lid back on the canister WITHOUT and element inside? Filter, wishful thinking! No increased blow by as a result of high oil pressure either.....or smokey exhaust.
JCinKY
PostPosted: Tue Apr 09, 2013 8:41 am    Post subject: Re: Oil pressure Reply to specific post Reply with quote
Kirk West wrote:
(quoted from post at 06:44:39 04/09/13) Yes, I"ve got blue smoke out the oil breather too. I suspect I may have some stuck piston rings since this tractor sat more than ran. Also has ran cold for who know how long. Will check out the relief valve as soon as this blizzard blows by.
Stuck/worn rings or liners would be indicative of that. Oil can be sucked into the cylinder on the intake stroke due to the vacuum induced by the piston traveling down the bore. Thus the blue smoke from exhaust.
Combustion products will be forced past the rings on the power stroke, thus the smoke from oil filler neck.
An ATF soak could help some by pouring a teaspoon down the spark plug hole and letting it set to free up stuck rings.
You can have all the snow you want...sunny and 72 here in Glendale, KY
Good Luck
Aaron from Iowa
PostPosted: Wed Apr 17, 2013 3:31 pm    Post subject: Re: Oil pressure Reply to specific post Reply with quote
I'm going to add a little more background info. In about '03-'04 a friend thoroughly went through the tractor after my grandad passed away, as it had been parked next to his shed for as long as I can remember. It was then repainted and parked inside another shed. It was maybe ran 5 or 6 times between then and now. It's been probably 3 or 4 years since the last time it was started, but this is the first time the oil pressure read high or a knock was heard. When it gets a bit warmer, I'm planning to drop the pan and do a sludge check, as well as check out the pressure relief valve.
He had a second N that needs quite a bit more attention than this one, so I'm hoping this is an easy fix.
Royse
PostPosted: Wed Apr 17, 2013 3:57 pm    Post subject: Re: Oil pressure Reply to specific post Reply with quote
Funny you should post again today on this subject.
I started my 9N this afternoon for the first time since last fall.
Oil pressure gauge pegged above 50 PSI and stayed there!
It was running at a consistent 20 to 30 last year.
I had that happen on an 8N once and it was the relief valve.
I haven't taken this one apart yet to see what the cause is,
but when I do I'll let you know.
Dropping the oil pan might not be as easy as you think.
May want to find that manual. Smile
Aaron from Iowa
PostPosted: Wed Apr 17, 2013 4:47 pm    Post subject: Re: Oil pressure Reply to specific post Reply with quote
Yeah, the oil pan isn't a whole lot of fun. I had to drop it on the other N a few years back to rebuild the oil pump.
I'd like to switch to a multi-viscosity detergent oil on this tractor, which is my biggest reason for wanting to drop the pan. The other is to double check and make sure there aren't any animal nests or walnuts in the pan.
I DID find my FO-4 finally
Royse
PostPosted: Wed Apr 17, 2013 7:00 pm    Post subject: Re: Oil pressure Reply to specific post Reply with quote
The archives here are full of discussions on multi-vis oils and what type to use.
General opinion seems to be to use 10W-30 or 15W-40 weight quality oil.
The Old Hokie has posted a lot of information including temperature charts
and graphs on the differences which helped me make up my mind what to
run.
Your tractor, your choice. Smile
Aaron from Iowa
PostPosted: Fri Apr 26, 2013 6:40 pm    Post subject: Re: Oil pressure Reply to specific post Reply with quote
I drained the oil today, and found a nice sized pile of crud in the plug. Sad I'm thinkin' the pump sucked a whole lotta that stuff up and plugged some lines... So I'm trying to plan ahead for when I've got the pan off. What kind of tools should I have on hand for un-clogging oil lines? Wire/drill bits/pipe cleaners? Any specific diameters? Is there a better way?
Thanks,
Aaron
Goto page 1, 2  Next
Page 1 of 2
