SPARK PLUG WIRES
GEO/2/8NS/now 3
PostPosted: Mon Apr 08, 2013 7:40 pm    Post subject: SPARK PLUG WIRES Reply to specific post Reply with quote
Recevied new plug wires that are the oem type for my
frt dist 8N,the question I have.they are color code
#1 and #4 are obvious but 2&3 are the same lth.
Does any one have the correct color code for the
spark plug wires.Ive been looking but could not find
it. Thanks George
Dell (WA)
PostPosted: Mon Apr 08, 2013 9:36 pm    Post subject: Re: SPARK PLUG WIRES Reply to specific post Reply with quote
George........never heard of color coded sparkie wires. I have seen tinted clear insulation on display hot-rods. They ain't worth 'chit!!! The sparkies jump right thru the insulation and dance the nite away.
The original 9N sparkie wires were covered with a "braid" that could have been color coded as the rubber insulation for sparkie wires was NOT very good. Unless yer a sphincterly challenged originality inspector, I would NOT waste my $$$ on color coded wire.
The important thing, whether color coded ...or... black or yellow, is the center conductor is stranded copper wire and NOT modern resistive string. .......Dell, yer self-appointed sparkie-meister
36 Coupe
PostPosted: Tue Apr 09, 2013 2:34 am    Post subject: Re: SPARK PLUG WIRES Reply to specific post Reply with quote
Get some colored vinyl tape and code your wires.Early braided wires for Ford V8s had a colored thread to id them after they were pulled into the conduits.
GEO/2/8NS/now 3
PostPosted: Tue Apr 09, 2013 5:47 am    Post subject: Re: SPARK PLUG WIRES Reply to specific post Reply with quote
The wires I have are the OEM type that are color coded,these are the correct type that came with the tractor back in the day,they have the colored thread through them,each wire has A diff color.I"am making the tractor as correct as possible,the same as when my father bought it in 1949,my 2 other 88N will be work tractors this one will be my trailer queen.the other 2 have std type stuff on them and run fine, Thanks for the response George
HCooke
PostPosted: Tue Apr 09, 2013 9:42 am    Post subject: Re: SPARK PLUG WIRES Reply to specific post Reply with quote
Dell, Here are some color coded sparkie wires. Dennis Carpenter sells them. Supposed to be like original.
Old weldor
PostPosted: Tue Apr 09, 2013 12:52 pm    Post subject: Re: SPARK PLUG WIRES Reply to specific post Reply with quote
Ford cars before 1949 that had a front distributor on the v8 engines also had color coded plug wires.
GEO/2/8NS/now 3
PostPosted: Tue Apr 09, 2013 1:06 pm    Post subject: Re: SPARK PLUG WIRES Reply to specific post Reply with quote
Thanks guys for the input and H Cooke for the picture those are the ones that I have from Brilliam,I will use that photo to put my wires on.When I get the red and wheels on I will try to post A picture Fellow Ner George
