Draft Controll Cont'
8N-Bob
PostPosted: Tue Apr 09, 2013 8:05 am    Post subject: Draft Controll Cont' Reply to specific post Reply with quote
This is directed to Zane but all are welcome to help. Smile
Hi Zane:
You answered in Lisa's question about a washer placed below the draft control spring.
Here is my question.
I think I have the same problem. When in draft mode it does not lift. If you push down on the draft/position lever, That's push it a little lower then horizontal it will lift.
SO
Can I do the washer trick with mine of is it time to tear into it.
OH Yeah I did try adjusting the quadrent back and forth, that's how I got it to lift when pushing the draft/position lever down. Before that it did not lift at all.
Thanks.
Bob
Lisa K
PostPosted: Tue Apr 09, 2013 9:58 am    Post subject: Re: Draft Controll Cont' Reply to specific post Reply with quote
Just wanted to say we did the washer trick and adjusted quadrant and all works well now!! Thanks Zane!
8N-Bob
PostPosted: Wed Apr 10, 2013 4:19 am    Post subject: Re: Draft Controll Cont' Reply to specific post Reply with quote
Glad to hear that
I have not tore into things yet. The washer goes under the cover that you took off. Is that correct.
The way I look at it you take off the yoke, spring. cover and then the washer goes under the cover.
Now I just need Zane to say if my problem can be fixed with the washer trick.
Bob
JMOR
PostPosted: Wed Apr 10, 2013 6:42 am    Post subject: Re: Draft Controll Cont' Reply to specific post Reply with quote
8N-Bob wrote:
(quoted from post at 08:19:01 04/10/13) Glad to hear that
Bob
I'll let Zane address "will it fix my problem", but as to where washer goes, tractor side of #29.
8N-Bob
PostPosted: Wed Apr 10, 2013 7:38 am    Post subject: Re: Draft Controll Cont' Reply to specific post Reply with quote
I See it goes inboard of part "29"
Cool
Now looking at it I bet that will fix me also. Hey it's worth giving it a try. If not tear into the lift and replace the cam and buy the tool from Zane and adjust accordingly.
Bob
ZANE
PostPosted: Wed Apr 10, 2013 5:20 pm    Post subject: Re: Draft Controll Cont' Reply to specific post Reply with quote
Do it like the reply below and I think you will be in business.
I recently did it on my 660 and plowed about an acre this morning and draft control worked perfectly.
Zane
ZANE
PostPosted: Wed Apr 10, 2013 5:23 pm    Post subject: Re: Draft Controll Cont' Reply to specific post Reply with quote
Usually the hard part is getting that %$##$ yoke off the draft rod plunger.
Lots of times it take the big red torch.
Zane
8N-Bob
PostPosted: Thu Apr 11, 2013 8:00 am    Post subject: Re: Draft Controll Cont' Reply to specific post Reply with quote
Ok I'll give it a try. Maybe next week I'll pull it apart and see if that helps. I'll need to plow something to check that out. LOL. Maybe I'll start of a patch for blackberrys.
