Can an AC B (1939) be equipped with a front snow plow?
Eriklane
PostPosted: Tue Apr 09, 2013 4:39 pm    Post subject: Can an AC B (1939) be equipped with a front snow plow? Reply to specific post Reply with quote
Wondering if a B can plow snow with a front plow?
Paul from MI
PostPosted: Tue Apr 09, 2013 5:10 pm    Post subject: Re: Can an AC B (1939) be equipped with a front snow plow? Reply to specific post Reply with quote
If you can find a loader for it you are 90% there. Otherwise you are in for something of a fabrication job. You'll most likely end up adding a PTO driven hydraulic system as the original will be very slow and won't have enough oil capacity to lift much.
old
PostPosted: Tue Apr 09, 2013 6:22 pm    Post subject: Re: Can an AC B (1939) be equipped with a front snow plow? Reply to specific post Reply with quote
If it has hyds yes it can be done. Many years ago some one here posted pictures of a snow plow lift that he had on his B and he sent me pictures of it and I built one for my C and improved on its design.
Ted in NE-OH
PostPosted: Wed Apr 10, 2013 6:24 pm    Post subject: Re: Can an AC B (1939) be equipped with a front snow plow? Reply to specific post Reply with quote
Don't forget tire chains, makes a world of difference. Also weight, either weights or CaCL in rear tires.
2 types
PostPosted: Fri Apr 12, 2013 3:27 pm    Post subject: Re: Can an AC B (1939) be equipped with a front snow plow? Reply to specific post Reply with quote
One of mine has a hydraulic plow run by a GM power steering pump and a Farmall valve.
The other has what appears to be a factory, manual lift front blade.
