JD 70D axle/bullgear nut
Unstyled G Guy
PostPosted: Tue Apr 09, 2013 8:08 pm    Post subject: JD 70D axle/bullgear nut Reply to specific post Reply with quote
Had to take the axles out of the rearend of my JD 70 diesel tonight. When I got the second nut off the axle I notice the threads in it were mostly stripped out of the nut. My question is are the nuts in the 50's and 60's the same as the 70's? Going to try to find another one and might make my search easier. Thanks in advance for the replys!
Bob
PostPosted: Tue Apr 09, 2013 8:35 pm    Post subject: Re: JD 70D axle/bullgear nut Reply to specific post Reply with quote
From the .pdf parts catalogs available jdparts.com...
Model "50" axle nut part # B350R
Weight 0.66 LBS 0.30 Kg
Diameter 1.500 IN
Thread 12
Thickness 1.125 IN
Across Flats 2.000 IN
Flange OD 2.750 IN
Material Grade STEEL
Model "60" AND Model "70" axle nut part # A76R
Weight 1.30 LBS 0.59 Kg
Diameter 1.500 IN
Thread 12
Thickness 1.250 IN
Across Flats 2.250 IN
Flange OD 3.625 IN
Material Grade CAST
Kent Petersen
PostPosted: Wed Apr 10, 2013 3:59 pm    Post subject: Re: JD 70D axle/bullgear nut Reply to specific post Reply with quote
i have some on hand Kent
