Author |
Message |
JohnDeereJimOhio Long Time User
Posted: Wed Apr 10, 2013 8:24 am Post subject: 8n Electrical Issues |
I found an 8n for 500 bucks in good shape. oweber
says he just spent around 750 in it re-doing
electrical and carb and some other things and his
wife said it has to go. He said it runs fine then
burns the coil out. He said its a 6v system. I think
I can buy it and sell it and make a few bucks for
some other projects but what do you think is wrong
with it? |
Back to top |
Royse Tractor Guru
Joined: 17 Jan 2011 Posts: 15595 Location: Ionia County Michigan
Posted: Wed Apr 10, 2013 8:30 am Post subject: Re: 8n Electrical Issues |
Excessive coil current. If it is still 6 volt as he said, they may have left
the original ballast resistor (on the back of the dash) out of the circuit. |
Back to top |
Bruce (VA) Tractor Guru
Joined: 24 Feb 2003 Posts: 16222 Location: Old Church VA
Posted: Wed Apr 10, 2013 8:33 am Post subject: Re: 8n Electrical Issues |
" He said it runs fine then
burns the coil out"
Front or side coil?
The most likely cause is leaving the key on.
If it has a front coil, the next likely cause is no ballast resistor or bypassing the ballast resistor.
Google 'wiring diagrams JMOR' and find the one that fits the tractor.
75 Tips
Back to top |
Posted: Wed Apr 10, 2013 8:36 am Post subject: Re: 8n Electrical Issues |
At 500 is it a good deal? Decent metal.. Tires are all holding air but nothing special... |
Back to top |
Randy-PA Regular
Joined: 19 Oct 2011 Posts: 68 Location: Waterford, Pa.
Posted: Wed Apr 10, 2013 8:45 am Post subject: Re: 8n Electrical Issues |
I would scoop that tractor up in a heartbeat!
Like others have already said: check the balast resistor
Back to top |
souNdguy Tractor Guru
Posted: Wed Apr 10, 2013 9:36 am Post subject: Re: 8n Electrical Issues |
if it's only issue is burning the coil out.. and it runs 'ok' and looks 'ok' then 500$ is awesome.
most liekly it is a wireing issue.
like coil is wired hot al the time.. not switched.. or if a front mount.. as said.. might not have the ballast ressitor.. if it is 12v.. may be wrong coil / resistor combo.
you can likely make 1000$ off it by buying at 500 and selling at 1500 and just checkignthe wireing and adding a coil or resistor.. net profit of maybee 950$ |
Back to top |
Posted: Wed Apr 10, 2013 9:49 am Post subject: Re: 8n Electrical Issues |
Here is a pic of it
Back to top |
Posted: Wed Apr 10, 2013 10:13 am Post subject: Re: 8n Electrical Issues |
The tractor is well worth $500.
And you are doing the gentleman a favor; if he couldn't get it running after dropping $750 in it, you are saving him money & frustration.
For some folks, keeping an old tractor running would be like me trying to play golf.
75 Tips
Back to top |
Posted: Wed Apr 10, 2013 11:02 am Post subject: Re: 8n Electrical Issues |
it's a lil ugly.. but I'd have arm wrestled you .. and cheated. to win it for 500$
frankly.. for 500$.. if it ran and had no tin I'd have gotten it.. and i don't even particularly like N's.. :)
the engine alone is worth it. |
Back to top |
HCooke Tractor Guru
Posted: Wed Apr 10, 2013 3:29 pm Post subject: Re: 8n Electrical Issues |
Yep, that's a good deal. Google 'JMOR Wiring diagrams' and you will find the wiring diagram for that tractor. |
Back to top |
