Starter/wiring on 40s
JEC
PostPosted: Wed Apr 10, 2013 11:44 am    Post subject: Starter/wiring on 40s Reply to specific post Reply with quote
The first of many dumb questions..
I"ve managed to get all my connections loose and sanded. I have 12 volts at the battery and the positive cable shows 12 volts at the starter and not even a click or hum. There is 1 green wire that was hanging down from the rest of the wiring hanging down toward starter that has a plug on it, but I don"t see anything it should plug to? Any ideas?
The only type of wiring going to the starter is the positive cable direct to battery. Is this right? I"d like to make sure I"m wired up right before I take the starter to get tested.
My dash light lights up now! lol 1 small step.
Mark-Ia
PostPosted: Wed Apr 10, 2013 1:57 pm    Post subject: Re: Starter/wiring on 40s Reply to specific post Reply with quote
You can check your starter by hooking a set of jumper cables to it.
jCarroll
PostPosted: Wed Apr 10, 2013 3:19 pm    Post subject: Re: Starter/wiring on 40s Reply to specific post Reply with quote
No..........
In addition to the battery cable, there is a wire attached to the switch post which feeds the instrument panel.
See here for the wiring diagram, or go to
www.jd40.com
Rusty wheel
PostPosted: Thu Apr 11, 2013 11:52 am    Post subject: Re: Starter/wiring on 40s Reply to specific post Reply with quote
If the starter frame has a good ground to the tractor frame and you have 12 volts to the starter, then you must have a bad switch. They do go bad. You can check that right on the tractor.
