JD # 7 Military Field Plow
Rustrunner
PostPosted: Wed Apr 10, 2013 3:46 pm    Post subject: JD # 7 Military Field Plow Reply to specific post Reply with quote
Have an Army #7 WW II Field Plow, and need parts to complete it. Was only patly there when purchased, but want to get it operational for Portland SHow Working on list of what is needed, mostly braces between beams, a hitch part, springs, and a few other things - making a list ???? Any Help ??????<
Thanks Dan
tim s
PostPosted: Wed Apr 10, 2013 5:48 pm    Post subject: Re: JD # 7 Military Field Plow Reply to specific post Reply with quote
What kind of plow is this and how was it used??
Rustrunner
PostPosted: Wed Apr 10, 2013 5:56 pm    Post subject: Re: JD # 7 Military Field Plow Reply to specific post Reply with quote
A JD #7 plow is just a very heavy duty 4-14 bottom moldboard plow - just for plowing fields, however was designed to plow a depth of 6" to 14".
Quite big, 4 bottom plow weighs around 2300#.
Go TO:
http://www.easy39th.com/files/TM_5-1008_Plow,_Bottom_and_Disc_Towed-Type_Four_14_inch_Bottoms_Deere_Model_7_1943.pdf
Tyler-MO
PostPosted: Thu Apr 11, 2013 4:08 am    Post subject: Re: JD # 7 Military Field Plow Reply to specific post Reply with quote
I wanted to call you back but saw this post instead. ive never seen a No 7 plow anywhere except for pictures. I'd suggest contacting Dave Wolf bedacompany@yahoo.com as it's possible he may know someone with NO. 7 parts. From what I can tell the No 7 you have is the same as other No 7 plows. The only thing I would wonder is if they received a US Govt property number or similar as the military tractors made by JD did.
Tyler the Plow Guy in IL
Rustrunner
PostPosted: Thu Apr 11, 2013 5:44 am    Post subject: Re: JD # 7 Military Field Plow Reply to specific post Reply with quote
Thanks Tyler, sent a msg to Dave. Looks like there are very few of these around. This is the only one I have ever seen.
Am sure that this unit was Army, and I picked it up just so it would not go to the scrap yard. I think it would be quite some piece to have completed, would look good plowing 12-14# deep behind our CAT RD7 or Diesel 40.
Will be at the Tri-State Portland IN Swap meet with a big sign asking for info or parts.
Thanks again Dan
Rustrunner
PostPosted: Thu Apr 11, 2013 5:54 am    Post subject: Re: JD # 7 Military Field Plow Reply to specific post Reply with quote
Also working on a 8 bottom 1914-15 Case-Sattley and need some beam parts if anybody has a junk one?
tim s
PostPosted: Thu Apr 11, 2013 7:13 am    Post subject: Re: JD # 7 Military Field Plow Reply to specific post Reply with quote
What would the Military use these for??
Rustrunner
PostPosted: Thu Apr 11, 2013 10:30 am    Post subject: Re: JD # 7 Military Field Plow Reply to specific post Reply with quote
Tim - Not sure why the Army had them, but have heard that some were used on Pacific Islands to plow fields to raise crops for the troops there. Better than shipping everything in. Maybe someone else can provide better info.
tim s
PostPosted: Thu Apr 11, 2013 11:33 am    Post subject: Re: JD # 7 Military Field Plow Reply to specific post Reply with quote
That makes a little bit of sense,,and common sense was still used back then,,,not much any more...
