Case rod
hog farmer
PostPosted: Wed Apr 10, 2013 6:28 pm    Post subject: Case rod Reply to specific post Reply with quote
What size should the rod journal be if your crank was turned to fit a case 1070 rod? What would be the Clevite part number for the bearings?
G1355
PostPosted: Wed Apr 10, 2013 6:34 pm    Post subject: Re: Case rod Reply to specific post Reply with quote
Post on case forum, it will be more helpful, not to many people on the mm forum will know much about case's
Ray Tellin
PostPosted: Wed Apr 10, 2013 7:42 pm    Post subject: Re: Case rod Reply to specific post Reply with quote
I think they are 2.75 if I remember right.
Tim Yates
PostPosted: Thu Apr 11, 2013 4:13 am    Post subject: Re: Case rod Reply to specific post Reply with quote
I used case 1030 rods which was a 451 diesel. They are 2.75" I believe the 1070 is the same thing.
Molineub55
PostPosted: Thu Apr 11, 2013 9:35 am    Post subject: Re: Case rod Reply to specific post Reply with quote
What is the length center to center? On what stroke were you using these rods?
Tim Yates
PostPosted: Thu Apr 11, 2013 10:22 am    Post subject: Re: Case rod Reply to specific post Reply with quote
Trying to remember off the top of my head. I think 10.6" long, c to c. I have a 7" stroke, 800 jugs. The wrist pins start out the bottom of the sleeve and the piston was a little short in the hole about .100"/.125". I milled the top of the crank case and the top of the jugs to get the piston up in the cylinder better. The wrist pin does not come out the bottom now at all.I had to shorten the lifters some for clearance under the jugs. No gaskets under the jugs, only permatex.
Greg Herriott
PostPosted: Thu Apr 11, 2013 10:46 am    Post subject: Re: Case rod Reply to specific post Reply with quote
rod journal 2.7490,Clevite # CB-686P standard,rod length c-c 10.5 inches.
LW
PostPosted: Sat Apr 13, 2013 6:07 pm    Post subject: Re: Case rod Reply to specific post Reply with quote
Canted cap rod for 4cyl and 6cyl case engines, 2.750 crank pin, CB-686P bearing, 10.500 Center to Center, Dsl is a heavier rod with 1.500 pin and gas version is 1.250 pin. There are several versions of this rod some gun drilled and some not etc...
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
