Engine oil leak on a 206 gas
mmfun
PostPosted: Sun Apr 14, 2013 2:01 pm    Post subject: Engine oil leak on a 206 gas Reply to specific post Reply with quote
Does it make a difference the way the head gaskets go on this engine I put the copper color down someone told me the copper color should go towards the head did I do it wrong? Also looks like I have oil coming out between the head and block just on the push rod side would this be caused by the head gasket installed wrong?
T.R.K.
PostPosted: Wed Apr 17, 2013 8:54 am    Post subject: Re: Engine oil leak on a 206 gas Reply to specific post Reply with quote
I'm surprised no one else answered this.
Are you using any gasket sealer?
What I have had to do on several MMs to get the head gasket to seal (keep the water and oil in their places) is to put a thin bead of permatex #2 around each water port and the pushrod passages and another thin bead all the way around the outside edge top and bottom sides to get the head gasket to hold back both the water and oil.
Do not get any sealer on the rings around the cylinders or it will blow as soon as the sealer burns out.
One old timer said to use Indian Head gasket shellac. (if only I could find it.)
There is also a product called copper kote that someone recommended.
Take this for what its worth. I have been told in the past that head gaskets are supposed to be put on dry and have had good success with most automotive and small engine head gaskets.
Joe Pro
PostPosted: Sat Apr 20, 2013 8:44 am    Post subject: Re: Engine oil leak on a 206 gas Reply to specific post Reply with quote
The copper side does go up. I"ve put them on dry and with sealent. Using the spray copper kote has had the best success. I use it on any copper head gaskets anymore. If you had the heads machined ( surfaced )I would put them on dry.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
