Roosa Master gauge
detown
PostPosted: Thu Apr 18, 2013 2:51 pm    Post subject: Roosa Master gauge Reply to specific post Reply with quote
I have a problem that I hope someone can help me with.
I am helping a friend of mine with a John Deere 350c dozer.
The problem started when the rack and pinion on the throttle lever stripped. I am a machinist, so I managed to make a knew rack gear.
Upon removing the pump I also found that the retaining screw for the metering valve sleeve was broken. Got that fixed and now have the pump back together.
This is a Roosa Master model C with the metering valve update kit( R.M. 18387-AT31165).
The problem is that with this mod you need the gauge 18314 to set the governor end play for the metering rod.
Nobody around here seems to have the gauge. If i knew what the dimension was on the gauge I could make one easily.
If anybody has this gauge and could give me the measurment it would really help me out.
Dennis
SBogusta
PostPosted: Fri Apr 19, 2013 8:37 am    Post subject: Re: Roosa Master gauge Reply to specific post Reply with quote
There was a guy on the Crawlwer Discussion board who knew a whole lot about Roosamaster pumps. You might try posting there or giving crawlwer heaven a call they deal with nothing but older Deere dozers.
Good Luck
Steve
