Sump pump powered by city Water
Goto page 1, 2  Next
Earl-IL
PostPosted: Thu Apr 18, 2013 6:55 pm    Post subject: Sump pump powered by city Water Reply to specific post Reply with quote
Have any of you in tractor land tried one of these?
Ohio Case
PostPosted: Fri Apr 19, 2013 3:24 am    Post subject: Re: Sump pump powered by city Water Reply to specific post Reply with quote
We have been installing them for a few years, they are a whole lot better than the battery powered ones, and alot cheaper. As long as you have at least 20 psi water pressure they will work just fine. For every gallon used it will pump 2 gallons. Go to www.libertypumps.com
danmcdonald
PostPosted: Fri Apr 19, 2013 4:45 am    Post subject: Re: Sump pump powered by city Water Reply to specific post Reply with quote
I don't think most of us here have city water.
Leroy
PostPosted: Fri Apr 19, 2013 5:15 am    Post subject: Re: Sump pump powered by city Water Reply to specific post Reply with quote
Don't need a sump pump. My wife sells them tho. Problem is if town is without power for you to use a regular one then the town will be without power to refill the water tower and if everybody that needed a pump would have them they would be draining the water tower with no water left for fire fighting or other nessary uses and then also the sewage system they are plumbed into would not be able to operate because of no power and would have to dump untreated sewage. A lot of places would not be allowed to have them dump into the roof drain. If you are out in the country and have a spring that would provide the needed constant supply of water for them to operate and then you could dump on top of ground that would be the only good place for them.
Dusty MI
PostPosted: Fri Apr 19, 2013 5:17 am    Post subject: Re: Sump pump powered by city Water Reply to specific post Reply with quote
I would that most city pumps would have back up generators.
Dusty
Russ from MN
PostPosted: Fri Apr 19, 2013 5:57 am    Post subject: Re: Sump pump powered by city Water Reply to specific post Reply with quote
I am sure they need a lot more pressure than most springs provide.
David G
PostPosted: Fri Apr 19, 2013 6:18 am    Post subject: Re: Sump pump powered by city Water Reply to specific post Reply with quote
They are probably an eductor type, I have used them to empty hot tub. It takes a lot more water than they pump, work off vacuum like a carburetor venturi.
massey 333
PostPosted: Fri Apr 19, 2013 9:10 am    Post subject: Re: Sump pump powered by city Water Reply to specific post Reply with quote
Like others said,towns have gen.backups.Plumbing supply houses say they sell 20-30 to 1 of those vs.electric ones.But you need a outside water supply to run one.
Earl-IL
PostPosted: Fri Apr 19, 2013 12:14 pm    Post subject: Re: Sump pump powered by city Water Reply to specific post Reply with quote
Thank you, I think it will work well for me I have city water with 45 lb. pressure.
Earl-IL
PostPosted: Fri Apr 19, 2013 12:18 pm    Post subject: Re: Sump pump powered by city Water Reply to specific post Reply with quote
Thank you. I have city water. The town has Diesel Generator to run if we were out of power.
Earl-IL
PostPosted: Fri Apr 19, 2013 12:19 pm    Post subject: Re: Sump pump powered by city Water Reply to specific post Reply with quote
Thanks for your reply.
Earl-IL
PostPosted: Fri Apr 19, 2013 12:25 pm    Post subject: Re: Sump pump powered by city Water Reply to specific post Reply with quote
Thanks. Earl
Earl-IL
PostPosted: Fri Apr 19, 2013 12:29 pm    Post subject: Re: Sump pump powered by city Water Reply to specific post Reply with quote
Thanks.
Earl-IL
PostPosted: Fri Apr 19, 2013 12:30 pm    Post subject: Re: Sump pump powered by city Water Reply to specific post Reply with quote
OK.
Earl-IL
PostPosted: Fri Apr 19, 2013 12:31 pm    Post subject: Re: Sump pump powered by city Water Reply to specific post Reply with quote
Yes, Thanks.
Goto page 1, 2  Next
Page 1 of 2
