47A-Testing Oil Gauge
oldmanandakid
PostPosted: Fri Apr 19, 2013 7:33 pm    Post subject: 47A-Testing Oil Gauge Reply to specific post Reply with quote
Is there way to check the oil gauge before I attempt to fire up this old beast?
DScott
PostPosted: Fri Apr 19, 2013 7:48 pm    Post subject: Re: 47A-Testing Oil Gauge Reply to specific post Reply with quote
oldmanandakid wrote:
(quoted from post at 20:33:03 04/19/13) Is there way to check the oil gauge before I attempt to fire up this old beast?
I can crank my hand crank start A and B with the spark plugs disconnected and they will show oil pressure before they start. You can take the plugs out to make it easier. Of course it's even easier on the electric start models.
Husker44A
PostPosted: Fri Apr 19, 2013 7:50 pm    Post subject: Re: 47A-Testing Oil Gauge Reply to specific post Reply with quote
Oil test cock is under the flywheel. 3/4 wrench opens it. If
oil comes out its full.
gtx1967jewison@yahoo.com
PostPosted: Fri Apr 19, 2013 8:02 pm    Post subject: Re: 47A-Testing Oil Gauge Reply to specific post Reply with quote
Remove it from the engine, spin it over & in a few cranks oil
will come out if the pump is working Smile
Lee B
PostPosted: Fri Apr 19, 2013 8:18 pm    Post subject: Re: 47A-Testing Oil Gauge Reply to specific post Reply with quote
Screw it into an air chuck and let a spare tire down to 15 psi, then put the gauge with air chuck on it and note where 15 psi registers.
Priming the engine before starting is a nice touch but defeats the purpose of assembly lube and if you used some you should be fine without priming.
