I need help with a carburetor kit
bciowa
PostPosted: Sat Apr 20, 2013 12:45 pm    Post subject: I need help with a carburetor kit Reply to specific post Reply with quote
I am looking to get a carburetor kit for a DLTX 8 and I am looking for some advice as to where to get a good quality kit with good gaskets that won't leak. Some kits online say they fit an A but they aren't very specific about what model. Any help would be great. Thanks, Bryan.
bciowa
PostPosted: Sat Apr 20, 2013 2:17 pm    Post subject: Re: I need help with a carburetor kit Reply to specific post Reply with quote
Thanks for your help. The carburetor is a DLTX 8 brass body off of an A. I will give popinjohn.com a try. Thanks again, Bryan.
Hayrack
PostPosted: Sat Apr 20, 2013 4:50 pm    Post subject: Re: I need help with a carburetor kit Reply to specific post Reply with quote
Actually guys... I have had great luck soaking them clean. Use your normal carb cleaner first to get all the grease and grime off, then I soak them in a 50/50 solution of muratic acid and water. I have found that most of them are rusted shut and the acid will eat every bit of rust out and when you pull it out, it will look like a new piece of cast! Then, use baking soda and water mixed to neutralize the acid. Good luck!
Mark-Ia
PostPosted: Sun Apr 21, 2013 5:26 am    Post subject: Re: I need help with a carburetor kit Reply to specific post Reply with quote
Most of those kits fit all the DLTX carbs. Only difference is the gasket under the bowl nut for the #51 carb for a G. It is usually included.
