UTS rear end fluid
goatboy
PostPosted: Wed Apr 24, 2013 5:31 pm    Post subject: UTS rear end fluid Reply to specific post Reply with quote
What is the best oil to use in the rear end of a UTS? Thanks
Alan K
PostPosted: Wed Apr 24, 2013 5:48 pm    Post subject: Re: UTS rear end fluid Reply to specific post Reply with quote
I believe they originally came with 140w, some places you can still get it, but I think mostly 80-90w or 85-140w would be easier to find and should work ok. I know in the ZA manual it mentioned about thinning the rear end oil with kerosene for winter operation and then draining and replacing with 140w in the spring.
oleclint
PostPosted: Wed Apr 24, 2013 7:26 pm    Post subject: Re: UTS rear end fluid Reply to specific post Reply with quote
I have used and still use 90# in my uts & utu tractors. 90# has never failed me over theyears.clint
redgems
PostPosted: Wed Apr 24, 2013 8:01 pm    Post subject: Re: UTS rear end fluid Reply to specific post Reply with quote
I just bought 15 gallons of 85-140 for my utn and 30wt low ash for propane engine.
They are Acalia (sp) brand from CIH.
Tony
Bob M
PostPosted: Sat Apr 27, 2013 2:02 pm    Post subject: Re: UTS rear end fluid Reply to specific post Reply with quote
I filled my UTU with 85W90 about 10 years ago - it seems to work fine.
The stuff in the rear end when I got the tractor was extremely stiff - almost a solid. In colder weather the shift lever was impossible to move until the engine had run 5 - 10 minutes with the clutch engaged. Replacing it with 85W90 eliminated the problem, and the transmission still runs nice and quiet.
goatboy
PostPosted: Sun Apr 28, 2013 1:23 pm    Post subject: Re: UTS rear end fluid Reply to specific post Reply with quote
My fluid was so thick some of it would not drain, and I had to scoop it out with my hands.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
