Oliver 1365 PTO Clutch lever
Robert from Qc
PostPosted: Thu Apr 25, 2013 9:31 am    Post subject: Oliver 1365 PTO Clutch lever Reply to specific post Reply with quote
The clutch lever on my 1365 is stuck in the upright position. No matter how hard I try I can't release it downward. I disconnected the lever from the cluch and the PTO works fine.
Wat could be the problem ? What is broken ? How do I repair this lever ?
rrlund
PostPosted: Thu Apr 25, 2013 12:25 pm    Post subject: Re: Oliver 1365 PTO Clutch lever Reply to specific post Reply with quote
Scratching my head. When the lever is up against the dash,it shuts the PTO off. When it's down horizontal it engages the PTO. If it's running when it's up,something must really be messed up.
Robert from Qc
PostPosted: Thu Apr 25, 2013 12:56 pm    Post subject: Re: Oliver 1365 PTO Clutch lever Reply to specific post Reply with quote
As I said I disconnected the lever from the PTO clutch shaft. So the shaft is released, as if engaged. I'm pretty sure the problem is with the lever, how difficult is it to repair ?
rrlund
PostPosted: Thu Apr 25, 2013 2:57 pm    Post subject: Re: Oliver 1365 PTO Clutch lever Reply to specific post Reply with quote
I think that's an over center clutch isn't it? Might be a broken fork so it won't release. I don't think there's a plate where you can get in to work on it. If that's it,you'll most likely have to split it.
There's a cover on the right hand side by the brakes that you can take off. Maybe if you shine a flashlight in there you can see what's going on.
MMChuck.
PostPosted: Thu Apr 25, 2013 3:26 pm    Post subject: Re: Oliver 1365 PTO Clutch lever Reply to specific post Reply with quote
If I rember right you need to push the knob in to relace the lever.
J. Schwiebert
PostPosted: Thu Apr 25, 2013 4:57 pm    Post subject: Re: Oliver 1365 PTO Clutch lever Reply to specific post Reply with quote
That is not an over center clutch. It is a dual stage clutch.
