Dearborn 19-59 Loader
BryHarper
PostPosted: Fri Apr 26, 2013 10:25 am    Post subject: Dearborn 19-59 Loader Reply to specific post Reply with quote
I have a 1941 9N that I"m interested in attaching a Dearborn 19-59 loader to. I have not purchased the loader yet as I am trying to see what all should be there. Plus what it will take to provide the hydraulic pressure for this. I noticed another thread with a person who had one of these already setup. Any suggestions / help would be appreciated.
old
PostPosted: Fri Apr 26, 2013 10:47 am    Post subject: Re: Dearborn 19-59 Loader Reply to specific post Reply with quote
Well first off if you have the 19 inch tires up front you will want to change them out to the 16 inch so you can go wider on the tires.
As for hyds it should have a hyd pump that runs off the crank shaft pulley which you will have to replace on your tractor for one that is drilled and tapped for the drive hub. When running a loader on that tractor you will also want something real heavy on the 3 point or the steering will be a bear
Ultradog MN
PostPosted: Sat Apr 27, 2013 4:20 am    Post subject: Re: Dearborn 19-59 Loader Reply to specific post Reply with quote
Are you sure you want to climb up over the 3 point arms and over the seat to get on your tractor? That's what you'll be doing with one of those pipe frame dearborns.
I wouldn't own one - unless the tractor was dedicated to loader work and i used it infrequently.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
