pre heater
massey 65 1961
PostPosted: Sat Apr 27, 2013 4:33 am    Post subject: pre heater Reply to specific post Reply with quote
Hello I have a Massey 65 I'm looking for the fuel line and or part number on line from fuel resiovoir bowl to pre heater on manifold. Or can I make one.
Jerry/MT
PostPosted: Sat Apr 27, 2013 5:56 am    Post subject: Re: pre heater Reply to specific post Reply with quote
All the ones I have seen have been fuel hose not steel.
massey 65 1961
PostPosted: Sat Apr 27, 2013 6:04 am    Post subject: Re: pre heater Reply to specific post Reply with quote
Thank you for the reply. I believe mine is a solid steel line type. That's only type I've ever seen.
hymie2lt
PostPosted: Sat Apr 27, 2013 6:20 am    Post subject: Re: pre heater Reply to specific post Reply with quote
Hi
I believe the part number you need is 189169m91
If you cant get one..I may be able to locate one for you?
Wayne
massey 65 1961
PostPosted: Sat Apr 27, 2013 6:39 am    Post subject: Re: pre heater Reply to specific post Reply with quote
Thank you Wayne for your reply. Could you see if you could locate me one please.
Dieseltech
PostPosted: Sat Apr 27, 2013 9:10 pm    Post subject: Re: pre heater Reply to specific post Reply with quote
CAV/Lucas/Delphi Thermostart instruction spec sheet lists steel line only to the heater unit as it can overheat causing rubber hose to fail if used. There are 3 flows available, low, medium and high. None should ever be used longer than 1 minute or there is a much greater risk of failure when it overheats.
Jerry/MT
PostPosted: Mon Apr 29, 2013 2:29 pm    Post subject: Re: pre heater Reply to specific post Reply with quote
My Ford 4610 uses a fuel hose (plastic or rubber?) to the Thermostart unit. I"ve never seen a metal one. Not trying to start an argument just stating my experience.
