Trying to go from a 6 lug hub to a 5 lug hub on 88
olivertractorpuller
PostPosted: Sun Apr 28, 2013 6:16 pm    Post subject: Trying to go from a 6 lug hub to a 5 lug hub on 88 Reply to specific post Reply with quote
I have a set of 5 lug mag wheels and im trying to figure out how to switch over to a 5 lug hub. No luck yet.
mikefullpull
PostPosted: Sun Apr 28, 2013 7:32 pm    Post subject: Re: Trying to go from a 6 lug hub to a 5 lug hub on 88 Reply to specific post Reply with quote
I believe if you get hubs from a boat trailer and buy bearings to match it might work, good luck.
olivertractorpuller
PostPosted: Sun Apr 28, 2013 7:34 pm    Post subject: Re: Trying to go from a 6 lug hub to a 5 lug hub on 88 Reply to specific post Reply with quote
Yea ive tried that. I cannot find a 5 lug boat trailer hub with the right bearings to fit the spindle
ollie gm
PostPosted: Sun Apr 28, 2013 8:22 pm    Post subject: Re: Trying to go from a 6 lug hub to a 5 lug hub on 88 Reply to specific post Reply with quote
I used to do this all the time with the old street rods we put together.
You find the hubs you want, measure the ID's and the spindle OD's then go to a bearing house or catalog for the bearings.
With the Chinese bearings available these days, you should be OK with a slow speed tractor and be on the cheap too.
There is an unlimited source of bearings online these days.
olivertractorpullerguy
PostPosted: Sun Apr 28, 2013 8:31 pm    Post subject: Re: Trying to go from a 6 lug hub to a 5 lug hub on 88 Reply to specific post Reply with quote
What do you mean by IDs and ODs
Craig Thompson
PostPosted: Sun Apr 28, 2013 8:38 pm    Post subject: Re: Trying to go from a 6 lug hub to a 5 lug hub on 88 Reply to specific post Reply with quote
I might be able to help cross reference a bearings set up with a hub
can you tell my what the inner bearing specs are inside diameter(diameter goes on spindle) and outside diameter of the bearing that fits near the hub.
same thing for the outer bearing specs inside diameter (diameter goes on spindle) and outside diameter that fits near the hub.
Schim
PostPosted: Mon Apr 29, 2013 5:05 am    Post subject: Re: Trying to go from a 6 lug hub to a 5 lug hub on 88 Reply to specific post Reply with quote
inside diameter of your hub and outside diameter of your spindle where the bearing rides
M.Genrich
PostPosted: Thu May 02, 2013 3:13 pm    Post subject: Re: Trying to go from a 6 lug hub to a 5 lug hub on 88 Reply to specific post Reply with quote
your not going to find a five bolt hub that will fit your spindles. saw the old ones off, couter bore the hole, and weld in trailer spindles. its been done for years.
