NAA weak hydraulic pump?
Tuna IL
PostPosted: Tue Apr 30, 2013 6:52 am    Post subject: NAA weak hydraulic pump? Reply to specific post Reply with quote
3pt lift is slow, hydraulic pump will lose prime overnight. With lift arms chained down , gauge at the test port, only showing 1100psi. Which would be about half of what it should be from searching the post on here. Just wanted someone to confirm my diagnosis. Should add it is a piston pump, not vain. I have ordered a shop manual just not here yet.
thanks
charlie
souNdguy
PostPosted: Tue Apr 30, 2013 7:26 am    Post subject: Re: NAA weak hydraulic pump? Reply to specific post Reply with quote
lotsa leaking from the top side?
Tuna IL
PostPosted: Tue Apr 30, 2013 7:32 am    Post subject: Re: NAA weak hydraulic pump? Reply to specific post Reply with quote
So I need to pull the side inspection cover and check for leaks form the piston?
old
PostPosted: Tue Apr 30, 2013 7:56 am    Post subject: Re: NAA weak hydraulic pump? Reply to specific post Reply with quote
Yep first thing to do is pull the dip stick inspection plate and have a look see. As for loosing prime that maybe worse problems like a pin hole in a line that runs threw the transmission
souNdguy
PostPosted: Tue Apr 30, 2013 8:03 am    Post subject: Re: NAA weak hydraulic pump? Reply to specific post Reply with quote
actually not so bad on the naa.. the naa uses external lines that run under the tractor.. not them bajeebers that run thru the tranny.
Tuna IL
PostPosted: Tue Apr 30, 2013 8:06 am    Post subject: Re: NAA weak hydraulic pump? Reply to specific post Reply with quote
Just checked again. The lift piston is moving in and out as it should with no leaks that I can see at all and no steams up top, while gauge showed 1100 psi. Weak pump?
old
PostPosted: Tue Apr 30, 2013 8:27 am    Post subject: Re: NAA weak hydraulic pump? Reply to specific post Reply with quote
If it has the vane pump good chance it is a weak pump
Kurt-NEPA
PostPosted: Tue Apr 30, 2013 9:02 am    Post subject: Re: NAA weak hydraulic pump? Reply to specific post Reply with quote
My first thought was that you had a major leak in the lift piston. Since you have checked that and it appears OK, I would check the pump further
Is the lift jerky or smooth? If its jerky, I would try bleeding the pump by the pipe plug on the top - front of the pump. If you are up for a task, pump in a clear plastic hose and run it to the fill hole under the seat. Start the tractor. If you see bubbles running though the plastic tube, you have a suction side air leak. If you just see oil, I'm thinking you might have a few broken or worn check valve springs inside the pump.
If it were mine, I'd bleed that pump and see if it improves things. Just break the pump bleed plug loose (just a bit) and run the tractor at slow idle. Loosen the pipe plug just enough for oil to flow. You may see bubbles. Once its only oil, tighten the plug and check the lift. Be careful, if the plug comes out with the tractor running, you'll be moping up oil all over the barn.
TunaIL
PostPosted: Tue Apr 30, 2013 9:42 am    Post subject: Re: NAA weak hydraulic pump? Reply to specific post Reply with quote
The lift is smooth, but very slow. If it sits more than a day I have to bleed the air from the pump at the pipe plug on front of pump. When bleeding the pump it takes 20-30 sec to go from bubbles to oil to get the air out.
WayneIA
PostPosted: Tue Apr 30, 2013 10:12 am    Post subject: Re: NAA weak hydraulic pump? Reply to specific post Reply with quote
A slow or weak piston pump and no air might be the check valves or check springs are wore out or gone, in the pump.
Kurt-NEPA
PostPosted: Tue Apr 30, 2013 10:39 am    Post subject: Re: NAA weak hydraulic pump? Reply to specific post Reply with quote
Tuna, I think you are looking at a pump rebuild. Loosing the prime overnight is a classic sign of a failed pump shaft seal. Over the years, the seal wears a groove in the wobble shaft that requires replacing both. In order to do that you will have to replace both bearing.
I also think you will find that you have check valve problems on several cylinders. Replacing the balls and springs is a fairly easy fix.
If you are up to a full pump rebuild, post back and we can help. Its a little more involved than normal wrenching.
Tuna IL
PostPosted: Tue Apr 30, 2013 3:59 pm    Post subject: Re: NAA weak hydraulic pump? Reply to specific post Reply with quote
Thanks, I will go for the full pump rebuild, It will be a month or two as I drive OTR. Until then I keep reading on here.
thanks
charlie
36 Coupe
PostPosted: Tue Apr 30, 2013 4:17 pm    Post subject: Re: NAA weak hydraulic pump? Reply to specific post Reply with quote
Better make sure you have the right fluid in the hydraulic before you say bad pump...
Geo-TH,In
PostPosted: Fri May 03, 2013 10:33 am    Post subject: Re: NAA weak hydraulic pump? Reply to specific post Reply with quote
I had a piston pump. Did a rebuild, purchased everything. Later I discovered the seal that wears a grove can be pressed in a different location and I could haved used the old shaft.
My problem was a broken spring. It too lost prime.
George
