ford 3000 3 point hitch trouble
unhappy ford 300
PostPosted: Wed May 01, 2013 4:37 pm    Post subject: ford 3000 3 point hitch trouble Reply to specific post Reply with quote
have 3000 ford tractor, 3 point hitch shutters when lifting and will not lift much of a load. had the pump removed and checked OK, had the top cover removed and checked , cleaned with new piston seal installed. when pumo is on tractor a pressure check at pump outlet shows pressure of 500 psi and the gauge needle fluxuated when 3 point is lifting but pressure never goes much more than 500 psi. it appears the system is bypassing some where but I do not know where to look. I need some help please????
RodinNS
PostPosted: Wed May 01, 2013 6:15 pm    Post subject: Re: ford 3000 3 point hitch trouble Reply to specific post Reply with quote
Probably in the flow control valve... IIRC, there is a spool in there that allows excess flow to be dumped to sump. If the valve sticks and doesn't shift for a fast lift... most flow is dumped to sump and low pressure. Valve will be by your right heel as you sit in the seat.
Rod
unhappy ford 300
PostPosted: Wed May 01, 2013 6:52 pm    Post subject: Re: ford 3000 3 point hitch trouble Reply to specific post Reply with quote
is that the valve located in the sump draian valve
unhappy ford 300
PostPosted: Wed May 01, 2013 6:56 pm    Post subject: Re: ford 3000 3 point hitch trouble Reply to specific post Reply with quote
is that the valve located in thesump drain valve
RodinNS
PostPosted: Wed May 01, 2013 7:30 pm    Post subject: Re: ford 3000 3 point hitch trouble Reply to specific post Reply with quote
It's located in the hydraulic manifold... above the releif valve and just below the lift cover. It's bolted into the side of the rear axle center housing. Should have a black finger knob on it.
Rod
