Engine Oil Capacity 300 U
5 Fordward
PostPosted: Wed May 01, 2013 4:56 pm    Post subject: Engine Oil Capacity 300 U Reply to specific post Reply with quote
I have a 300 Utility that I recently purchased and in the process of changing the engine oil, putting in 4 qts fills it to the full mark on the dipstick, plus removing the top plug on the side of the oil pan oil runs out. The manual says 6 qts. What am I missing?
Zachary Hoyt
PostPosted: Wed May 01, 2013 5:45 pm    Post subject: Re: Engine Oil Capacity 300 U Reply to specific post Reply with quote
if the bottom of the oil pan is seriously crushed I suppose you could lose that much volume, but it would be externally obvious.
Zach
CNKS
PostPosted: Wed May 01, 2013 6:05 pm    Post subject: Re: Engine Oil Capacity 300 U Reply to specific post Reply with quote
The pan itself holds 5 quarts up to the upper petcock, the other quart is for the filter. I don't know if the dipstick accounts for the extra quart, it should because the filter drains to the pan when the engine is off. You either have a big dent in the pan or a massive amount of crud in the pan.
