Farmall H no spark
Harrison58
PostPosted: Wed May 01, 2013 5:10 pm    Post subject: Farmall H no spark Reply to specific post Reply with quote
I have a farmall h I'm working on and can't get it to fire. The coil is good. The points on the distributer are open. But I'm not getting any spark at the point or plug. Any idea what could be the next guess.
Wayne in MN
PostPosted: Wed May 01, 2013 5:16 pm    Post subject: Re: Farmall H no spark Reply to specific post Reply with quote
Dirty points are likely suspect. Use a fine abrasive followed by chemical cleaner (lacquer thinner).
Harrison58
PostPosted: Wed May 01, 2013 5:20 pm    Post subject: Re: Farmall H no spark Reply to specific post Reply with quote
Thanks I will try that. I've also heard that the condenser could have gone bad. It hasn't ran in 15+ years.
John T
PostPosted: Wed May 01, 2013 5:29 pm    Post subject: Re: Farmall H no spark Reply to specific post Reply with quote
This is more then you asked for but it can help diagnose the cause.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=5745
John T
John Ts Ignition Troubleshooting
Harrison58
PostPosted: Wed May 01, 2013 8:10 pm    Post subject: Re: Farmall H no spark Reply to specific post Reply with quote
I tried cleaning the points and still nothing. I might pull the condenser and see what happens. Any other suggestions. Thanks
El Toro
PostPosted: Thu May 02, 2013 4:53 am    Post subject: Re: Farmall H no spark Reply to specific post Reply with quote
Use a volt meter or test lite to see if you have battery voltage to your coil. With the points open and your ignition switch in the "on postion" you should have voltage on both terminals on your coil. Hal
Harrison58
PostPosted: Thu May 02, 2013 6:15 pm    Post subject: Re: Farmall H no spark Reply to specific post Reply with quote
Thanks for the help everyone I got spark now!! Thanks agin Harrison
