WD9 reason for water in oil
Grabatire
PostPosted: Wed May 01, 2013 7:41 pm    Post subject: WD9 reason for water in oil Reply to specific post Reply with quote
I posted a few days ago about a WD9 having water in the oil. Well I found the reason. The water jacket was so rusted that a portion of the sleeve bore had developed pinholes, allowing water to seep in between the sleeve and the sleeve bore and drip into the crankcase. I am quite surprised too. I thought the sleeve would have fit tight enough to the bore that water wouldn't be able to slip by.
Oh well, I have another block.
stumper
PostPosted: Wed May 01, 2013 10:45 pm    Post subject: Re: WD9 reason for water in oil Reply to specific post Reply with quote
I have used locktite to seal sleeves in when
sleeve bore has a hole in it (throne rod) and has worked real good. clean it up and see if its an option,stumper
Va Gasman
PostPosted: Thu May 02, 2013 3:35 am    Post subject: Re: WD9 reason for water in oil Reply to specific post Reply with quote
I lubricated a H sleeve when I installed it with 600 degree red silicone. I expected a similar problem. Greased the bore and sleeve well and it slid in like it was greased. Next day trimmed the squeeze with a knife. It has worked well.
