Oliver 1850 runs rough
cjackman
PostPosted: Thu May 02, 2013 9:42 am    Post subject: Oliver 1850 runs rough Reply to specific post Reply with quote
Ok folks, I have an Oliver 1850 gasser that runs rough. It idles
pretty choppy and don't run smooth. When I first got the old girl
she ran smooth as new ( last season). Now it just plain runs
rough. Instead of a smooth idle it'll puff a little and runs rough.
Seems like a carb problem but with some adjustments seems
worse. Has recent plugs and wires. Anybody know
approximate carb settings? Thanks.
bobbyboywestcentIN
PostPosted: Thu May 02, 2013 1:13 pm    Post subject: Re: Oliver 1850 runs rough Reply to specific post Reply with quote
points, rotor, and cap. your carb probably hasn't went out of adjustment since last season.
J. Schwiebert
PostPosted: Thu May 02, 2013 2:26 pm    Post subject: Re: Oliver 1850 runs rough Reply to specific post Reply with quote
Which carburetor? The Aluminum M-S or the cast iron Zenith?
cjackman
PostPosted: Thu May 02, 2013 2:50 pm    Post subject: Re: Oliver 1850 runs rough Reply to specific post Reply with quote
It has the aluminum carb on it
J. Schwiebert
PostPosted: Thu May 02, 2013 5:51 pm    Post subject: Re: Oliver 1850 runs rough Reply to specific post Reply with quote
Well I believe you. But I have a lot more questions. How can I contact you and I am gone for a few days! J.
cjackman
PostPosted: Fri May 03, 2013 4:25 am    Post subject: Re: Oliver 1850 runs rough Reply to specific post Reply with quote
Ok. Easiest way to reach me is to give me a call. 419-769-2418. Thanks
ollie gm
PostPosted: Fri May 03, 2013 6:01 pm    Post subject: Re: Oliver 1850 runs rough Reply to specific post Reply with quote
You probably simply have a slug of water in your gas. Drain your old fuel and add a couple of gallons of fresh. Then clean your sediment bowl if equipped and add a bottle of gas dryer. Take the tractor for a cruise around the pasture. If you had water in the gas this should make it run normal.
Ethanol fuel only has a shelf live of maybe 3 months under ideal conditions. On top that, it is a water sponge, it will absorb 50 tp 60 times more water than 100% pure gas.
Don't take too many things apart at once. You just don't want to fix anything that doesn't need it.
Good luck!
