Author |
Message |
Ring gear Guest
Posted: Tue May 07, 2013 10:43 am Post subject: Vista question |
Can I use the differential from a G1000 in a Vista rearend? |
Back to top |
Coco Guest
Posted: Tue May 07, 2013 12:33 pm Post subject: Re: Vista question |
I am trying to find the front grill wrap around....anybody help, know where to look or have one? |
Back to top |
G1355 Tractor Expert
Posted: Tue May 07, 2013 12:45 pm Post subject: Re: Vista question |
Yes I'm 99% sure, think the vista was all the same except, the steps, platform and fenders. It was just more user friendy. |
Back to top |
G706 Regular
Posted: Tue May 07, 2013 9:21 pm Post subject: Re: Vista question |
I'm pretty sure the ring and pinion is different on a Vista. |
Back to top |
MMDEL Long Time User
Posted: Fri May 10, 2013 8:40 am Post subject: Re: Vista question |
Yes they were different, but they will fit. I would not put a G1000 Ring Gear set in a Vista. Unless it is just for show or parade. The angle of the teeth were made different on the Vistas to put more pressure at the base of the tooth. Vista Ring and Pinion were an update for the G1000.
MMDEL |
Back to top |
roy drewis New User
Posted: Wed May 22, 2013 9:23 pm Post subject: Re: Vista question |
The G-1000 vista is a different rear end and there was also an update to the Vista in the angle of the pinion to ring gear angle. There was also an upgrade to the carrier unit for the ring gear to bolt to. G-1000 is way too light for the Vista series. |
Back to top |
