Problem running still!
Dave/MO
PostPosted: Wed May 08, 2013 2:15 pm    Post subject: Problem running still! Reply to specific post Reply with quote
41 9N 12v still will not run. found seat and needle bad. Put in new repair kit for carb. Replaced points and still will not start. Will turn over but it just wont start. I noticed that fuel is leaking out of the carb at the exhaust pipe. If it isn"t raining tomorrow I am changing plugs and wires. What is the gap on the plugs. I am putting AL437 plugs in tractor. Sorry I keep reposting same issue but I do not do this a lot. I am lost.
G W
PostPosted: Wed May 08, 2013 2:39 pm    Post subject: Re: Problem running still! Reply to specific post Reply with quote
The spark plug gap is 0.025 Point Gap is 0.015. Pull a plug out and check for spark. If no spark start from the ignition and make sure you have voltage to the coil. If all is good including the coil it's probably the condensor
Dave/MO
PostPosted: Wed May 08, 2013 2:46 pm    Post subject: Re: Problem running still! Reply to specific post Reply with quote
Just replaced condenser and points
Bruce (VA)
PostPosted: Wed May 08, 2013 3:13 pm    Post subject: Re: Problem running still! Reply to specific post Reply with quote
First, replace the plugs. You flooded it, they're fouled & it will be it next to impossible to start. You don't need to toss them; heat the tips for a few seconds w/ a propane torch to burn off the invisible spark-robbing deposits from today's additive filled gasoline........or wash them in lacquer thinner.
It takes three things for an engine to run: spark at the right time, compression, & fuel in the right mixture. For the moment, forget about compression & concentrate on narrowing the problem down to spark or fuel.
There are three very important tools you always need to have in your N tool box: a 3 inch piece of wire w/ alligator clips on each end, an old spark plug w/ the gap opened to at least 3/16” ( ¼” is better) and a 7/16 box end wrench. (see tip # 50 at the link below) And, you really do need a working ammeter on the tractor; it is a very important diagnostic tool. With these tools, you can quickly narrow down most N problems to spark or fuel.
First, check for fuel. Get a can & put it under the carb. Remove the bolt in the bottom of the carb; as long as the fuel is turned on, you should see gas flowing out of the carb. Let it run for at least 30 seconds. If it’s a dribble, or runs for 5 seconds & stops, or none at all, you have solved half the problem: it’s fuel related. If gas flows well out of the carb & only stops when you turn it off at the sediment bowl, chances are very good it’s not a fuel problem. So, next, turn the key on, crank the engine & look at the ammeter. What is the needle doing? Does it show a constant discharge, no movement at all, or does it move back & forth slightly? Next, get the old plug, ground it to a rust & paint free spot on the engine, turn the key on & crank the engine. If the spark jumps the 3/16” gap, you probably don’t have a spark problem. If it won’t jump the 3/16” gap, you have a spark problem. If the ammeter needle shows a constant discharge, or doesn’t move at all, that also tells you that you have a spark problem. Jump the ignition switch w/ your jumper wire & see what happens. If it runs, you found the problem. If it doesn’t have spark after you jump the ignition switch, post back for more info on further troubleshooting. (and do not forget to turn the ignition switch off; see tip # 38)
If it does not have gas coming out of the carb at a steady stream w/ the bolt out for at least 30 seconds, you have a fuel problem. First, remove the gas cap. Your vent could be clogged & it vacuum locked. If that doesn’t work, tap the carb bowl w/ a hammer handle in case the float is sticking closed. (don’t whack it w/ the head of the hammer; you can crack the bowl). If you still don’t see gas flowing, the N has three fuel screens; one in the brass elbow, one in the top of the sediment bowl & one on the stem of the sediment bowl in the gas tank. Check the screen in the elbow & the screen in the top of the sediment bowl. (don’t worry about the one in the tank) Both probably need to be cleaned. If you have the fuel knob turned on all the way, & 1 gallon or less in the tank, it may be trying to feed off of the reserve inlet which is probably clogged. Only open it 2 full turns. Put at least 2 gallons in the tank. (and do not forget to turn the gas off; see tip # 9)
There are ways to check for spark & fuel that work & ways that don't. For example, having gas to the carb is nice, but having it past the float is what counts! That’s why removing the 7/16” bolt in the bottom of the carb is the way to check for fuel. And, same thing w/ spark at the plugs. Some folks think that checking for spark means pulling a plug wire off & looking for one. Well, it's the distance the spark jumps at the plug that gives you the info you want. It takes about 17kv to jump a 3/16" gap & 22kv to jump ¼” in the open air. Remember, it’s 14psi outside of the engine & about 90psi at a 6:1 compression ratio in the cylinders & compressed air creates electrical resistance, so you really need the 17-22kv to fire the plugs when the engine is running. A store bought plug checker will work better than an old plug because it won’t shock the snot out of you like an old plug might!
75 Tips
Breeze Wood
PostPosted: Wed May 08, 2013 7:54 pm    Post subject: Re: Problem running still! Reply to specific post Reply with quote
This is not a popular suggestion but my 49 8n starts up better when the gap is widened on the points ... just under 1/8" by eye.
someday may fix the dizzie but works well otherwise - for years.
at any rate it will tell you if the advance is out of adjustment.
