finding serial number on Model A Avery
Carl Finley
PostPosted: Fri May 10, 2013 5:54 am    Post subject: finding serial number on Model A Avery Reply to specific post Reply with quote
could someone please tell me where to find the serial number on Model A Avery thanks Carl
Pete in Cal
PostPosted: Fri May 10, 2013 6:55 am    Post subject: Re: finding serial number on Model A Avery Reply to specific post Reply with quote
Look on the right side frame rail {from the operators seat} about amidships. More info @ bfavery dot com. HTH Pete
Carl Finley
PostPosted: Fri May 10, 2013 10:35 am    Post subject: Re: finding serial number on Model A Avery Reply to specific post Reply with quote
I have looked there many times and still can't find thanks antwat Carl
Pete in Cal
PostPosted: Fri May 10, 2013 1:28 pm    Post subject: Re: finding serial number on Model A Avery Reply to specific post Reply with quote
Carl, Pulled the book, says "The serial number is located on the right side of the frame where it bolts to the final drive." Sorry about the wrong information, should have looked at my "A" first. Pete
K-Mo
PostPosted: Sat May 11, 2013 3:34 am    Post subject: Re: finding serial number on Model A Avery Reply to specific post Reply with quote
The serial number should stamped into the top of the right frame rail channel near the rear. If the the frame to trans-axle mounting bracket has been broken, as is common, I have seen reinforcement material and welds covering the serial number.
Carl Finley
PostPosted: Sat May 11, 2013 8:07 am    Post subject: Re: finding serial number on Model A Avery Reply to specific post Reply with quote
I found the serial number which is 507 now I don't know what year it is thanks Carl
Pete in Cal
PostPosted: Sat May 11, 2013 1:06 pm    Post subject: Re: finding serial number on Model A Avery Reply to specific post Reply with quote
Carl, The number should have a prefix as listed on this site: example 3A507 or # A 507. Look on left side of this page "serial numbers", Pete
Carl Finley
PostPosted: Sun May 12, 2013 12:47 pm    Post subject: Re: finding serial number on Model A Avery Reply to specific post Reply with quote
I found number A-507 but listing don't go back far enough I think mine is a 1938 thanks again Carl
