sharpening planner blades.
Goto page 1, 2, 3  Next
Geo-TH,In
PostPosted: Fri May 10, 2013 9:46 am    Post subject: sharpening planner blades. Reply to specific post Reply with quote
Has anyone been able to sharpen 13 inch dewalt planner blades? I know they aren't that expensive, 3 for $35 on ebay and you can use both sides.
I used to sharpen 6 in jointer blades on a surface grinder with magnetic chuck, but retired and no longer have access to surface grinder.
George
old
PostPosted: Fri May 10, 2013 9:55 am    Post subject: Re: sharpening planner blades. Reply to specific post Reply with quote
Check around you maybe able to find some one in your area that does saw blade sharpening and if so they should be able to do those blades for you
Ellis Kinney
PostPosted: Fri May 10, 2013 10:16 am    Post subject: Re: sharpening planner blades. Reply to specific post Reply with quote
George, I know how you feel. I used to teach machine shop and welding. When I retired I couldn't do anything. Now I have to pay to get knives sharpened. Ellis
VaTom
PostPosted: Fri May 10, 2013 12:43 pm    Post subject: Re: sharpening planner blades. Reply to specific post Reply with quote
Pickup for the sharpening services here would be an independent home center or a real hardware store or a larger shop. Several grinders near me, and very little industry around here. No problem with my 12 inch jointer knives, but they"re only sharp on one side.
My considerably larger planer came with a grinder attachment, real nice. No need to remove the knives from the cutter-head, the grinding wheel travels down the knife.
Dave Sherburne NY
PostPosted: Fri May 10, 2013 12:48 pm    Post subject: Re: sharpening planner blades. Reply to specific post Reply with quote
I think if you found someone to sharpen them for you you would pay close to $35 for 6 edges.
Geo-TH,In
PostPosted: Fri May 10, 2013 1:03 pm    Post subject: Re: sharpening planner blades. Reply to specific post Reply with quote
Old, that someone who shapens saws blades is writing this post. Have my own sharpner. I know it's too expensive to pay someone to sharpen planner blades. What I have is said to be throw aways. I put lots of wood through the planner before I change blades. Just trying to visualize how I could make an attachment for an 8 inch grinder. Hoping someone has sucessfully done it.
I miss having access to the machine shop at school. Even though it was a WW2 army surpluss surface grinder, it worked perfectly. Loved the magnetic chuck too. Wish I had a surface grinder. Might have to add that to my bucket list. Currently there is nothing in the bucket.
Anyone have an old surface grinder that a retired person could afford?
George
Dick2
PostPosted: Fri May 10, 2013 1:44 pm    Post subject: Re: sharpening planner blades. Reply to specific post Reply with quote
I just used a few different fine stones and sharpened them myself. Saw on a woodworking site someone cut 2 slots in a block of wood to hold tha blades at the right angle so he could sharpen 2 edges with a hand stone at one time. Unfortunately, I don't know the angle to set the saw to make those cuts.
36 Coupe
PostPosted: Fri May 10, 2013 1:47 pm    Post subject: Re: sharpening planner blades. Reply to specific post Reply with quote
I sharpen 3 edges for 9 bucks.Depend on blade condition.
Russ from MN
PostPosted: Fri May 10, 2013 2:08 pm    Post subject: Re: sharpening planner blades. Reply to specific post Reply with quote
I get mine sharpened locally for somewhat less than the cost of new blades.
flembo
PostPosted: Fri May 10, 2013 2:26 pm    Post subject: Re: sharpening planner blades. Reply to specific post Reply with quote
I have, I welded up a jig a little over 12" long I believe the angle on my blades was 37 deg.after welding I set it up on the Bridgeport with the head tilted to 37 deg. and trued it up I milled a step for the blade to set on and drilled and tapped a series of holes then made a stepped plate to clamp the blade in place. I grind them on the surface grinder can do my 6" jointer blades as well.A few strokes with a fine stone does it.
GordoSD
PostPosted: Fri May 10, 2013 3:17 pm    Post subject: Re: sharpening planner blades. Reply to specific post Reply with quote
Would a floor model large belt sander like the old Craftsman work/ I have one and many more metal work projects on it than steel. It also has the disc sander and table on it. Indispensable.
Geo-TH,In
PostPosted: Fri May 10, 2013 3:26 pm    Post subject: Re: sharpening planner blades. Reply to specific post Reply with quote
Dick 3,
I was thinking about doing something similar or using a bench belt sander.
George
old
PostPosted: Fri May 10, 2013 5:00 pm    Post subject: Re: sharpening planner blades. Reply to specific post Reply with quote
Ya the guy I would go to to sharpen things like that was 72 back in 1992 and is long since gone. He was very good but also got to old to do it any more. I know a guy who could still do it but he is also a machinist and has many tools I would love to learn to use
tomtirediron
PostPosted: Fri May 10, 2013 5:17 pm    Post subject: Re: sharpening planner blades. Reply to specific post Reply with quote
How about a tight older radial arm saw with a fine stone?
Jack345
PostPosted: Fri May 10, 2013 7:36 pm    Post subject: Re: sharpening planner blades. Reply to specific post Reply with quote
I've been using my bench belt sander for years works pretty good. Take out the material stop and use complete bed (long part of bed not across) Try to hold original angle with final touch up on flat side of blade with a stone,also use a fine grit belt.
Page 1 of 3
