Grease Joint Rejuvenator
Goto page 1, 2  Next
DoubleR
PostPosted: Sat May 11, 2013 4:54 am    Post subject: Grease Joint Rejuvenator Reply to specific post Reply with quote
I was looking at one yesterday at TSC for 49 bucks. It was made by Innovative Products in the USA no less. It looked like you put some penetrating oil or something similar in it, put it over the zerk and hit it with a hammer. It appears to open the froze grease zerk up. Looks like it could be kind of handy compared to a torch or zerk replacement. Has anyone used one? Is it a waste of money or does it really work?
Dean
PostPosted: Sat May 11, 2013 5:22 am    Post subject: Re: Grease Joint Rejuvenator Reply to specific post Reply with quote
I have little use for one.
Installing a new zerk will usually fix such problems.
Dean
charlie n
PostPosted: Sat May 11, 2013 5:56 am    Post subject: Re: Grease Joint Rejuvenator Reply to specific post Reply with quote
Sometimes it's the zerk but sometimes it's the passage .When that happens you have to remove the zerk out to clean it.$49.00 buys a lot of zerks.JMO.
DiyDave
PostPosted: Sat May 11, 2013 6:26 am    Post subject: Re: Grease Joint Rejuvenator Reply to specific post Reply with quote
They don't work, most of the time. I pull the zerk, and spray kroil in the hole, and that gets most of the mildly frozen ones clear. Sometimes I put a pipe nipple and a cap on the fitting, and pour kroil in the nipple, and re cap. On one fitting, it took 6 weeks, to eat through the rust and crud.
sflem849
PostPosted: Sat May 11, 2013 6:29 am    Post subject: Re: Grease Joint Rejuvenator Reply to specific post Reply with quote
They work pretty good. The ZerkZapper is good. The guy who sells them is on AgTalk and has given some tips on how to use them. #1 is use actual liquid oil not a spray can.
Bobcatz
PostPosted: Sat May 11, 2013 10:10 am    Post subject: Re: Grease Joint Rejuvenator Reply to specific post Reply with quote
Warning!
I worked several years on heavy equipment and heating grease joints was common pratice until we were told about a man doing the same thing was killed when the joint got hot and the ball check which is in all the zerk fittings shot out and went into the guys heart! Take precautions!
rustyfarmall
PostPosted: Sat May 11, 2013 11:23 am    Post subject: Re: Grease Joint Rejuvenator Reply to specific post Reply with quote
Bobcatz wrote:
(quoted from post at 11:10:08 05/11/13) Warning!
Had to be more things preceding that incident. That tiny little spring behind the ball check doesn't have the ability to make that happen.
Oxy/acetylene torch would be too hot, and probably destroy that spring. A small propane torch works very well. Just heat the zerk 'till the worms come out, put the grease gun on it and start pumping. If that doesn't work, remove the zerk, dig into that old grease with a pointy object, spray some penetrating oil in, install a new grease zerk, and start pumping.
Bobcatz
PostPosted: Sat May 11, 2013 11:35 am    Post subject: Re: Grease Joint Rejuvenator Reply to specific post Reply with quote
The spring has nothing to do with the checkball shooting out. It is the expansion behind the check ball from the heat that caused the checkball to shoot out!
Glrnn F.
PostPosted: Sat May 11, 2013 11:51 am    Post subject: Re: Grease Joint Rejuvenator Reply to specific post Reply with quote
I wish it were always that simple.
Glenn F.
36 Coupe
PostPosted: Sat May 11, 2013 4:24 pm    Post subject: Re: Grease Joint Rejuvenator Reply to specific post Reply with quote
You could make one with some steel stock for little money.You will need a drill press to drill a straight 1/4 inch hole.Then make a plunger.I just change the fitting.5 cents each from a big jar full at a store I stop at.
greygoat
PostPosted: Sat May 11, 2013 6:04 pm    Post subject: Re: Grease Joint Rejuvenator Reply to specific post Reply with quote
J.C. Whitney used to sell them for $12.95 !
john *.?-!.* cub owner
PostPosted: Sat May 11, 2013 7:21 pm    Post subject: Re: Grease Joint Rejuvenator Reply to specific post Reply with quote
Friend of mine was working on a backhoe, using a torch on the swing pin. it blew the complete fitting out and buried it in a wall stud. Thankfully it completely missed him.
sflem849
PostPosted: Sun May 12, 2013 4:59 am    Post subject: Re: Grease Joint Rejuvenator Reply to specific post Reply with quote
When I worked in Ag Retail I saw one shoot out while the kid was heating it. It flew out with force. I must not have learned too much...I now stand to the side when heating them.
rustyfarmall
PostPosted: Sun May 12, 2013 6:44 am    Post subject: Re: Grease Joint Rejuvenator Reply to specific post Reply with quote
Bobcatz wrote:
(quoted from post at 12:35:57 05/11/13) The spring has nothing to do with the checkball shooting out. It is the expansion behind the check ball from the heat that caused the checkball to shoot out!
Way too much heat. A small propane torch is all that is needed.
MeAnthony
PostPosted: Sun May 12, 2013 6:52 am    Post subject: Re: Grease Joint Rejuvenator Reply to specific post Reply with quote
What I've seen most often is dried grease behind the zerk rather than a problem with the zerk itself. Typically I remove the zerk and dig out what crud I can with a tiny allen wrench. On something like a pillow block bearing, welding wire is handy to clear the passage around the bearing race.
This solves most of them; really nasty ones I squirt some carb or brake parts cleaner into the hole to dissolve the blockage.
Anthony
Goto page 1, 2  Next
Page 1 of 2
