New Chain saw
Goto page 1, 2  Next
C.R.
PostPosted: Sun May 12, 2013 9:36 am    Post subject: New Chain saw Reply to specific post Reply with quote
I had to have a new saw the Mcculloch was a hunk of junk from day one and I finaly got fed up I got a Husqvarns 240 nice saw cuts well appears to have plenty of power I hope it lasts
gtractorfan
PostPosted: Sun May 12, 2013 10:21 am    Post subject: Re: New Chain saw Reply to specific post Reply with quote
I've had these for a long time, heat with wood and have had good luck with them. I'm curious why yours was junk from day one. Is it a newer one, not made like they used to be?
Bill Lisbon
PostPosted: Sun May 12, 2013 11:05 am    Post subject: Re: New Chain saw Reply to specific post Reply with quote
Like from going from Hamburger to steak.
C.R.
PostPosted: Sun May 12, 2013 12:45 pm    Post subject: Re: New Chain saw Reply to specific post Reply with quote
well I think it is a newer model and I think it was probably the homeowner grade not a pro model but it was always goofy and wouldnt oil I finaly pulled the line out of the oil tank and shot compressed air through it and got a hunk of metal shavings out of it and then it oiled, but it was never a good saw
jon f mn
PostPosted: Sun May 12, 2013 2:35 pm    Post subject: Re: New Chain saw Reply to specific post Reply with quote
I have a 350. Starts and runs great, lots of power (more than my friends Stihl that has the same size motor) cuts good. It's a lot lighter than the stihl too. BUT it has a lot of plastic and that breaks a lot. The dealer that sold it to me said he's had to replace a few of the handles because they got pulled off when the bar got pinched and the owner pulled to hard trying to get it out. Mine got broke too but I was able to drill a through bolt and fix the problem. It had a screw screwed in from each side.
View user's profile AIM Address
jeffcat
PostPosted: Sun May 12, 2013 8:58 pm    Post subject: Re: New Chain saw Reply to specific post Reply with quote
I would guess a 310 a 650 and a 700? I LOVE the 650 saws I have. right now I have 10 of them with a 605 and about eight 610 saws. All told I have almost 50 McCulloch saws.Yea the "hobby" got a little out of hand. The "aftermarket" mcculloch saws were all kinds of junk and I wouldn't touch them. You want pre 1999. A 650 in correct order is an almost 4hp cuttin beast! If you put a full chisel chain on.. oh baby. I also have two 650 saws with bow bars on them. Now you are talkin scareeerrry fast cutting.
JMS/.MN
PostPosted: Sun May 12, 2013 10:29 pm    Post subject: Re: New Chain saw Reply to specific post Reply with quote
I know it"s not right to bash a company on one experience, but here"s my McC story: started farming 41 years ago, BIL gave me a McC. He had given up on it, thought I might be able to use it to clear some land. BIL was a Cat mechanic on the Iron Range, northern MN, later taught at the tech school in Hibbing, so obviously a good mechanic.
Only way I could start it was crank it in a vise, start it, walk to where I needed it, while running. Had a 3 acre patch of woods near the road, left it out one night. Someone STOLE it! Only loss was, I left the gas can with it! Kharma is a beotch, just like THAT saw.
Bret4207
PostPosted: Mon May 13, 2013 3:32 am    Post subject: Re: New Chain saw Reply to specific post Reply with quote
A real McCulloch, something from 1985 or so or earlier is a fine saw. These things they call McCullochs from the past few years...just walk away.
Sadly, I can say the same thing about a lot of Huskys and Stihls too, unless you shell out $800-1000.00.
gtractorfan
PostPosted: Mon May 13, 2013 3:41 am    Post subject: Re: New Chain saw Reply to specific post Reply with quote
The one in the foreground is an 800, my dad had a 700. I was at the dealer long ago, he had the slightly used 800 and I couldn't pass it up! It runs smoother and beats the 650 thru big logs but is heavier and I'm "saving" it, will never have another like it,the 650 gets the most use.
OldFarmTractor
PostPosted: Mon May 13, 2013 3:44 pm    Post subject: Re: New Chain saw Reply to specific post Reply with quote
Still use my Dad's old Mac. It must be 50 years old. Only problem is that it takes at least 3 pulls to get it going after it sits for a few months.
Bret4207
PostPosted: Tue May 14, 2013 3:39 am    Post subject: Re: New Chain saw Reply to specific post Reply with quote
I have a Mac 1-50 that's just as old as I am, 53, and it still works great!
D beatty
PostPosted: Tue May 14, 2013 1:48 pm    Post subject: Re: New Chain saw Reply to specific post Reply with quote
Do you have a McCulloch Supper 55 in your collection? Dad had one with a 27 inch bar with a full chisel chain. It was a hand full it weighed 27 lbs and was gear driven and put out a little over 7 HP. It was a well built saw.
dcarp
PostPosted: Tue May 14, 2013 7:06 pm    Post subject: Re: New Chain saw Reply to specific post Reply with quote
I have one of the older small Mac's, cuts great, has a load of power, but once it's hot don't shut it off, will never start. Have to wait until it cools off to start it again.
Bret4207
PostPosted: Wed May 15, 2013 3:30 am    Post subject: Re: New Chain saw Reply to specific post Reply with quote
That sounds like a carb or ignition issue. Could be as simple as a new plug.
68massey204
PostPosted: Sun May 19, 2013 7:41 am    Post subject: Re: New Chain saw Reply to specific post Reply with quote
dcarp wrote:
(quoted from post at 20:06:00 05/14/13) I have one of the older small Mac's, cuts great, has a load of power, but once it's hot don't shut it off, will never start. Have to wait until it cools off to start it again.
Dad has a Mac 10-10, bought brand new in 1970, starts second pull cold every time and cuts great. But like you say, if you shut it off hot, you may as well go have lunch because it won't restart until it cools down. For the first fifteen years he owned that saw it cut 22 cords of firewood every year:-)
Goto page 1, 2  Next
Page 1 of 2
