930 and hydraulic question
Caseanonymous
PostPosted: Sun May 12, 2013 6:40 pm    Post subject: 930 and hydraulic question Reply to specific post Reply with quote
Thank you for everyone's input in my question about that 930 pto a few days ago I just had it adjusted too tight I got er now. I have another question. Are the hydraulic pumps in the 430 530 630 capable of running something constant such as a hydraulic sprayer pump or putting constant pressure on something like a woodsplitter that I have a separate valve on I would just have to lock the lever open on the tractor here. Also how about the same applications for a big 400? I lnow it would do it but would it damage them from gerting too hot? Thank you!
j hikemper
PostPosted: Mon May 13, 2013 6:54 am    Post subject: Re: 930 and hydraulic question Reply to specific post Reply with quote
the 430 and similar models have open center hydro ...meaning,,,they make fluid available while motor is runnin
bradley martin
PostPosted: Mon May 13, 2013 7:27 am    Post subject: Re: 930 and hydraulic question Reply to specific post Reply with quote
The 430 is not suitable for running an orgital hydraulic motor on a sprayer or such.....the hydraulic resevoir is too small and the oil will soon overheat.When it does it will damage the gaskets and seals in the valve. BTDT. It would likely be alright on a wood splitter application.
