john deere G oil leak in clutch
JDTim
PostPosted: Tue May 14, 2013 12:52 pm    Post subject: john deere G oil leak in clutch Reply to specific post Reply with quote
I have a 38 G that is leaking oil in the clutch housing. Not to good for the clutch pads. anyone know where this leak may be coming from. There is no cork seal or any other seal shown in the parts book.
MrJDMan80
PostPosted: Tue May 14, 2013 1:01 pm    Post subject: Re: john deere G oil leak in clutch Reply to specific post Reply with quote
is your engine oil over filled? is your breather pluged?
JDTim
PostPosted: Tue May 14, 2013 1:03 pm    Post subject: Re: john deere G oil leak in clutch Reply to specific post Reply with quote
oil is not over full, and breather is clear
RLA
PostPosted: Tue May 14, 2013 1:20 pm    Post subject: Re: john deere G oil leak in clutch Reply to specific post Reply with quote
There"s too much oil in the 1st reduction gear housing.
It"s either Engine Oil..from the rh main brg..
Hydraullic oil from the power trol thats leaking
to the transmission..
OR there"s water in the trans or some how
the trans is OVER. full..
Possible the bushing on the bully is shot
( If there"s a lot of play in the pulley)
Check & grease bearing too..
Kent Petersen
PostPosted: Tue May 14, 2013 4:25 pm    Post subject: Re: john deere G oil leak in clutch Reply to specific post Reply with quote
the trans does not have any thing to do with the frist rad cover it is oiled by engine oil if it has run many years on non detergent oil the return may be pluged or the engine may have a lot of blow by
gtx1967jewison@yahoo.com
PostPosted: Tue May 14, 2013 7:47 pm    Post subject: Re: john deere G oil leak in clutch Reply to specific post Reply with quote
If its allowed to run with the pulley stopped for any longer than is absolutely necessary, as i see nearly every one of them are at shows, it will do this also. The belt pulley (clutch) must be engaged! The oil slinger cant work when its stopped, & you're destroying the clutch & crankshaft. Also if a disc breaks & wedges itself, your tractor takes off & the only remedy is to kill the engine.
JOHN DEERE 70
PostPosted: Wed May 15, 2013 2:46 am    Post subject: Re: john deere G oil leak in clutch Reply to specific post Reply with quote
There should be a drain ,small in the shroud behind the clutch pulley. Also the hole should be on bottom in case somebody been there before.
JDTim
PostPosted: Wed May 15, 2013 1:45 pm    Post subject: Re: john deere G oil leak in clutch Reply to specific post Reply with quote
it does have alot of blow by. crank does not have much end play.
Kent Petersen
PostPosted: Wed May 15, 2013 5:29 pm    Post subject: Re: john deere G oil leak in clutch Reply to specific post Reply with quote
probley bad rings
