560 pulling?
pullinforfun
PostPosted: Sat May 18, 2013 8:30 pm    Post subject: 560 pulling? Reply to specific post Reply with quote
I got a farmall 560 with a 301 motor. i got CAP bros lightweight removable hubs, 18.4-34 agrimaster tires. road worn alot. 9 bolt pressed steel. engine is stock. regualar hoop drawbar. clay tracks around here. will my rear end get too light and will i just spin out???? Thanks
5500## weight class
Kelly N
PostPosted: Sun May 19, 2013 6:55 am    Post subject: Re: 560 pulling? Reply to specific post Reply with quote
It should do just fine in the 5500# class BUt you may need to go to a smaller tire to fit in the class unless the club you pull in allows the 18" tires in slow speed classes. I would suggest an adjustable hitch of pulling location.
pullinforfun
PostPosted: Sun May 19, 2013 9:42 am    Post subject: Re: 560 pulling? Reply to specific post Reply with quote
me and my buddy are gonna make a adjustable hitch , and once i get tires on ill clock my speeds, i think the slowest speed limit we have around here is 3mph. do you think 1st gear t/a pulled would still be to fast. im gonna leave it at stock rpm.
thanks for the info apperciate it.
ejr-IA.
PostPosted: Sun May 19, 2013 3:04 pm    Post subject: Re: 560 pulling? Reply to specific post Reply with quote
My 560 likes to go in the air so ballast the front end.I use 16.9 x 38 1st gear 2800 rpm the 301 can turn high rpm.
Welding man
PostPosted: Sun May 19, 2013 3:14 pm    Post subject: Re: 560 pulling? Reply to specific post Reply with quote
We pull 560's in the 8,000 to 12,000# classes in my neck of the woods. The more weight you pile on, the better they pull.
baldwin racing
PostPosted: Mon May 20, 2013 3:25 am    Post subject: Re: 560 pulling? Reply to specific post Reply with quote
560 will pull in 5,500 lbs class my brother placed 7th with a stock motor the big pull in pa....couple months ago... have to strip them pretty good he made 5500 with 18.4 38 and stock front end....pulled hydroilics made light weight seat and did some other simple stuff and made it fine and pulls good.
kelly
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
