8n regulator
Townsend Farm
PostPosted: Mon May 20, 2013 8:16 am    Post subject: 8n regulator Reply to specific post Reply with quote
I bought a voltage regulator at tractor supply for my 1952 8n.The package says fits 8n up to s/n 263844.My s/n starts with a 4.The regulator looks identical to the one on my tractor.Will it work?what is the diffrence between the two?They didn"t have the other regulator in stock.
JMOR
PostPosted: Mon May 20, 2013 8:56 am    Post subject: Re: 8n regulator Reply to specific post Reply with quote
Townsend Farm wrote:
(quoted from post at 12:16:13 05/20/13) I bought a voltage regulator at tractor supply for my 1952 8n.The package says fits 8n up to s/n 263844.My s/n starts with a 4.The regulator looks identical to the one on my tractor.Will it work?what is the diffrence between the two?They didn"t have the other regulator in stock.
Mounting holes changed somewhere about that time & some VRs need as adapter plate, but if you can mount it, it will work, electrically.
Townsend Farm
PostPosted: Mon May 20, 2013 9:08 am    Post subject: Re: 8n regulator Reply to specific post Reply with quote
Thanks jmor
Dell (WA)
PostPosted: Mon May 20, 2013 9:39 am    Post subject: Re: 8n regulator Reply to specific post Reply with quote
Townsend........don't fergitt to "polarize" yer new squarecan voltage regulator after installation. Just "arc-spark" the side-by-side ARM and BAT terminals, engine OFF. You can "polarize" as many times as it takes to feel warm'n'fuzzy ...er... charging. .......the charged Dell
souNdguy
PostPosted: Tue May 21, 2013 5:46 am    Post subject: Re: 8n regulator Reply to specific post Reply with quote
as said. mount as you need it to.. and it will work.. assuming genny and wireing are ok.
Townsend Farm
PostPosted: Wed May 22, 2013 8:01 am    Post subject: Re: 8n regulator Reply to specific post Reply with quote
do i polerize the voltage regulator this way if my system is a negative ground system?
JMOR
PostPosted: Wed May 22, 2013 8:54 am    Post subject: Re: 8n regulator Reply to specific post Reply with quote
(quoted from post at 12:01:01 05/22/13) do i polerize the voltage regulator this way if my system is a negative ground system?
same BATT to ARM regardless of whether pos or neg ground.
Townsend Farm
PostPosted: Wed May 22, 2013 9:09 am    Post subject: Re: 8n regulator Reply to specific post Reply with quote
Thanks Jmor
