MF 4253
WAYNE-N-TX
PostPosted: Tue May 21, 2013 6:40 am    Post subject: MF 4253 Reply to specific post Reply with quote
Baled hay this weekend with my new to me MF cab tractor. Everything went fine, was the first time with a monitor. With the engine running normal temperature and RPM's, working speed, there's no problems, engine sounds very good. When I cut the RPM's all the way back to an idle the oil light comes on. Rib the engine up, the light goes out.
Do you think it's an oil pump problem or maybe a censor. Like I said, the engine sounds normal, no clicks, knocks or vibrations.
WAYNE-N-TX
PostPosted: Tue May 21, 2013 7:03 am    Post subject: Re: MF 4253 Reply to specific post Reply with quote
Forgot to add, the oil is clean and has the right amount according the dip stick.
Masseynut(Australia)
PostPosted: Tue May 21, 2013 12:26 pm    Post subject: Re: MF 4253 Reply to specific post Reply with quote
First things first, remove the oil pressure switch and fit a master gauge.
This will tell you if the switch is faulty and/or if the oil pressure is down,
Evan.
danofarming
PostPosted: Thu Jun 06, 2013 6:34 pm    Post subject: Re: MF 4253 Reply to specific post Reply with quote
my 4243 did that, I put on a new sensor and added a gauge inside cab. I do not have to guess any more.
WAYNE-N-TX
PostPosted: Fri Jun 07, 2013 4:31 am    Post subject: Re: MF 4253 Reply to specific post Reply with quote
Don't have a manual yet, by any chance can you tell where the sensor is. There's a bush hog loader on it and hard to look inside engine compartment. I know it's somewhere around the oil filter (on most) somewhere. I bought a new sensor when I was near a MF place the other day.
